Hi, I have noticed recently my fuel consumption has increased quite drastically with no increase in mileage etc to account for it. I have taken live data with opcom on the way into work today which is a 25 minute drive. The car drives fine and there are no relevant fault codes to my knowledge, (just an intermittent glow plug fault). I think the Pulse ratio boost pressure solenoid is suspect as the only data is "_ _ _" for the 25 minutes and throttle position PWM servo signal column is 0% throughout. Also the boost pressure columns all look suspect I think as atmospheric is reading a constant 100KPa? Would someone be kind enough to cast an eye over the data and share their thoughts? Many thanks.
