~Is it possible to change a petrol's IPC to a diesel one?
i'm making a big assumption that the petrol speedo will have the dpf and glow plug lights in there... it's the rev counter that'll be the biggest issue... as petrols read to 8k rpm, diesels read to 6k... and in normal driving rarely go over 3k rpm...
So, if i were to change the card (plastic bit with the numbers printed on it) over from my diesel IPC, can the needle be programmed to read correctly.. i.e. read 2k less and do full sweep at 6k rather than 8k???
Just i have a meriva with the 1.3 cdti engine, and can;t find an IPC for that model with the large driver info screen, but there is one from a petrol meriva available (meriva's with the small engines speedo goes to 150 mph, all others go to 170)
