I have faced the same problem.. You'll need to change connector, metal pins are the same as in old small connector, you just need plastic piece.
At dealership, connector cost around 120EUR, but you can order directly from factory for 2-3EUR..
I have changed standard headlights to oem xenon, but still not did turning part.. As far as i know, I'm missing some wires from UEC to headlight, and from sensor to headlight. If you have more info please share :-)
