anyone no the Display Code Index for this part number 13301077
thanks
thanks
Need to know the year, model and fuel type
Gav
vauxhall zafira B exclusive 1.6 petrol 59 reg 2009 thanks
You will need 010 index code
thank you would no the version as well i have these numbers on ipc
code index001.version 7
code index003. version 4
code index005.version 2
Yes 005 02
right thank you very much your a star does it matter what codes are in for the ehu and display mines a cd30 with a bid display
Why are you changing the index codes?
I mess about with opcom and stuff it up i lost my d /side brake light and rear wiper stopped working i have the brake light working now but i am on008 index code
and version code index003. version 4 and I've had hell with it does it matter what the other codes are
Index codes only changed fuel settings on the ipc and display.
If your rear wiper and brake light have stop working then there is a fault.
