Results 1 to 5 of 5
    Member Donwoody1981's Avatar
    Apr 2012
    Wigan
    26
    Astra MK5
    Few questions on eeprom
    Im looking to get an eeprom dump from an IPC as somehow the security code has either been changed or its incorrect.
    Does anyone have a video or a how to as to what i need to do to get the dump and what i need to do it.
    I have never done this before by the way
      1,340
      some starting info,
      i use a hot air station, a decent temperature controlled soldering iron station, good solder, a flux pen. tweezers...
      then u need an eprom programmer like upa-usb or minipro with soic adapter...
      then you need to remove eprom from clocks, read the file
      then post up here and someone will tell you the code from it
      Apr 2012
      Wigan
      26
      Astra MK5
      Quote Originally Posted by soulman View Post
      some starting info,
      Are there any pics of which chip it is or a video would be ideal
      1,340
      its an 8 pin soic and its a 35080, you cant miss it, near the lcd connector if i remember
      1,340
      if you've never done this before including soldering etc etc, then i would advise get some old units to test on.. if your only going to do it the once, then much cheaper than the 150-200 i reckon its gonna cost to get the gear to do it
  1. newby with many many questions
    By Dubford in forum Astra
    Last Post: 15th June 2015, 12:52 AM
  2. A few questions for you lot
    By benboym3 in forum Vectra
    Last Post: 29th March 2013, 05:10 PM
  3. Questions about a future mod
    By mull3tt mk5 in forum Interior
    Last Post: 29th November 2012, 11:25 PM
