Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 40
    Member cross-keys's Avatar
    Feb 2012
    Ely, Cambs
    26
    Zafira B (57)
    Front Fog Lamp wiring
    Front fog lamps do seem to be available on cars with and without a REC, but the wiring is different depending on which you have.
    Here is the wiring diagram for cars with a REC.
    Here is the wiring diagram for cars without a REC.
    K39 is a relay that may be found in the boot where the REC would have been, presumably only on cars with front fog lamps as standard.
    This diagram also shows fuse 51 (15A) which provides the feed for the fog lamps - it's on the left sandwiched between fuse 52 and 56, but again, presumably only on cars with front fog lamps as standard.
    Here is an actual photo from a car with no REC and no factory fitted front fog lamps.
    Note that the following seem to be missing totally:
    Row 1 - F51 relay (front fog)
    Row 2 - K39 relay (front fog)
    Row 3 - Fuse F55 (rear electric windows)
    Row 4 - K5 relay (air con compressor, diesel w/o REC)
    Row 4 - F50 fuse (air con compressor, diesel w/o REC)
    Which only leaves:
    Row 1 - F52 fuse (15A) - accessory socket (X112TR) at the right rear of the car
    Row 1 - F56 fuse (15A) - accessory socket (X112) near the hand brake
    Row 3 - K71 relay - reversing lamp
    Row 3 - F57 fuse (7.5A) - rear lamps (inc reversing) and central locking
    Row 5 - K56 relay - rear wiper
    Row 5 - F54 fuse (30A) - front electric windows
    Row 5 - F53 fuse (7.5A) - outside mirror
      Feb 2012
      Ely, Cambs
      26
      Zafira B (57)
      I'm starting to think that retrofitting front fog lamps to non-REC Zafira Bs isn't possible. There seems to be no wiring in place, and no means of adding it because the pins in the Underhood Electrical Centre have been assigned to something else. I don't even think you could make up your own system with a custom loom and relay(s) as the foglamp switch should tell the computer to turn the lamps on, and it then does so - so you're stuffed!
      There appears to have been cars made with no REC but with front fog lamps, but if yours was made without, then the wiring/relays etc don't seem to be there.
      Someone once said that AFL's weren't retrofittable and I proved that wrong.
      The input to the relay is the wire which goes from the Instrument, so it is this that sends the signal to turn on the fog lamps.
      The power to the fuse & relay (which need adding) is spliced off the 6mm red cable feeding the other fuses, which ends up at Fuse 54.
      You then run cables from the relay to each bulb holder, the other side of the bulb holder goes to ground, which you could put them to a chassis earth, for which there are plenty in the engine compartment.
      Looks perfectly possible to me to add the wiring, the only possible complication is I don;t know if all clocks support the front fogs or if you need different ones.
      Feb 2012
      Ely, Cambs
      26
      Zafira B (57)
      Cool! - I'll run with the idea a little longer then.
      Here's the circuit for the switch which controls the front fogs:
      There needs to be a Grey/Blue wire going from the switch S122.5, to the instrument panel P3. This sends the signal that we want the fog lamps on or off. I know this is present on my vehicle as I documented this previously in the knowledge base.
      The feed from the instrument panel to the relay coil is found at P3 pin 13, and a Brown/White wire should lead to X1 pin 9, which is apparently somewhere on the passenger side of the car.
      If a connection can be picked up from here, then this could feed an aftermarket relay mounted in a convenient location. The remainder of the fog lamp wiring could be custom-built and need not follow any other diagrams.
      Next job for me would be to search out X1 (pin 9 - Brown/White). The diagram says it's here:
      Is that to the rear of the back door?
      Just wire straight through from point to point, don't worry about intermediate connectors like X1, they are there to make car assembly easier with the various options.
      I was going to suggest mounting the relay behind the glovebox, you just need to mount the relay and fuse on one of those holders like at the back.
      You will also find the 6mm power cable passing through below the passenger door cill.
      Feb 2012
      Ely, Cambs
      26
      Zafira B (57)
      Sounds like a plan! I guess one of the next steps would be to get sight of the 42-pin connector that connects to instrument panel P3. I'm confident that pin 28 (Grey/Blue) will be there, but I don't know what I will find in position pin 13 - possibly either a Brown/White wire on its way to connector X1, or an empty hole!
      I'll check the glovebox location while I'm at it too
      Member Donwoody1981's Avatar
      Apr 2012
      Wigan
      26
      Astra MK5
      So did we get any further with this i have an astra with no rec but i do seem to have the required relays and fuses fitted but no wiring for the actual fogs
      Apr 2012
      Wigan
      26
      Astra MK5
      And yes i am aware this thread is quiet old lol just wondering what i need to add to get these working
      Member RauliN11's Avatar
      May 2021
      Spain
      3
      Astra H
      Hi, i dont know if its too late to ask that, but i have a question.
      First of all, im from Spain so maybe my English is so bad.
      I have an Astra H GTC 1.6, and i dont have REC, i was trying to retrofit a front fog ligths, i bought a relay and a fuse, and i wired all, the only problem is the cable that goes to pin 9 in x1 does nothing, it doesnt matter if i put ON the front fog, this doesnt activate the relay, so i dont really know what to do now.
      VIP+ kadett90's Avatar
      May 2014
      Finland
      230
      Opel Astra H
      Do you have wiring between instrument and fog lamp relay via X1?
      Does the relay have power to pins 30 and 86?
      Have you program front fog light present?
  1. Fog light
    By rbngn91 in forum Vectra
    Last Post: 13th October 2018, 07:54 AM
  2. Replies: 1
    Last Post: 4th September 2013, 12:30 AM
  3. Replies: 0
    Last Post: 3rd September 2013, 11:10 PM
vectra c fog light fuse
vectra c front fog light fuse
front fog light fuse vectra c
vectra c fog light relay
vectra c front fog light relay
astra h fog light wiring
https:www.diagnostics.org.ukshowthread.php758-Front-Fog-Lamp-wiring
astra h fog light fuse location
vauxhall vectra c front fog light fuse
zafira b fog light install without REC
vectra c front fog light relay location
https:www.diagnostics.org.ukhelpshowthread.php758-Front-Fog-Lamp-wiring
vauxhall astra h fog light wiring loomzafira b front fog lightsvectra c fog light wiring diagramphotos of astra h fog lights wiring loomastra mk5 front fog light wiringvectra c fog light fuse locationzafira fog light wiring diagraminsignia uec fog light wiringhttps:www.diagnostics.org.ukshowthread.php758-Front-Fog-Lamp-wiringpage2vectra b fog light wiring astra h fog light installationvectra c fog light wiringvectra b front fog light relay and wiring
