my uec has pre-fog programming turned on. when i program it. but it didn't work. If ipc is not a solution, i will find uec with LL code and try.my opel zafira is diesel. IPC and UEC models needed for vehicles without rec if I can provide them.
IPC and UEC models for gasoline models with fog lights I do not have enough information to provide.
I am going to write a little more information to help you with the installation.
https://opel.7zap.com/en/car/a05/p/10/1-0/
use the link
Non-REC vehicles cannot use the following UEC codes to add front fog lights.
GS,GR,GT,GU,GX,GY,GZ,HA,HBHC,LM,LN,LP,LQ,LR
These UEC are from models with REC rear module.
The LL model is compatible with vehicles with front fog lights without REC rear module. The LL model is being used in vehicles with diesel DPF.
I can help you perform a standard installation if you can't perform an original installation.
https://suzuki88.mforos.com/407023/1...rruptor-ayuda/
You can use this link to see the alternative wiring diagram.
The power button may be in the original light control.
In the standard installation you only need the original Opel headlights and the original Opel bumper plastics
