Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 40 of 40
  1. #31
    Member AresUltio's Avatar
    Apr 2019
    İlçe
    32
    Astra Mk5 1.6 115 hp
    Quote Originally Posted by Gas gas View Post
    Attachment 2601
    You only need to see if the cables and connection of the light control and pin 13 of the ipc are available.
    Hello, I had the opportunity to try it today. I disconnected the cable from the p3 ipc 13 pin and connected the multimeter. "Neutral" didn't come up when I pressed the fog button. Then I tried it with a different QF and XA dial. "neutral" didn't come with them either. headlight switch 8 pin with ipc 28 pin wired. I tried the headlight switch in a different car, it runs the fog light. I can't get out of the problem. What cables did the other friend pull from xe1?. maybe uec supports it but doesn't allow it.
    • #32
      Member Gas gas's Avatar
      Dec 2020
      españa
      16
      zafira
      -hello don't use xe1.
      -the circuit has to be complete.
      ( view fotography )
      -Don't use a multimeter.
      -you can change ipc variants with a tech2 or gm mdi.
      the circuit has to be complete for testing.
      pin 13 only sends the correct electrical signal with the circuit terminated correctly.
    • #33
      Dec 2020
      españa
      16
      zafira
      :ni idea:
      Sorry to use several messages in a row.
      I can't use this forum correctly.
      I can't edit messages.
      I have a problem uploading photos.
      can you send me your email
      I want to help you achieve your project.
      Attached Thumbnails Attached Thumbnails Screenshot_2023-05-20-12-48-14-118_com.miui.gallery.jpg
    • #34
      Dec 2020
      españa
      16
      zafira
ID:	2604 photo esquema
    • #35
      Apr 2019
      İlçe
      32
Name:	not reccc.jpg
      Hello . I did not control only with the ipc 13 pin, I was going to pull the installation. I did not connect the only missing lamps. As in the photo, the positive lead was drawn from the rear fuse box to the relay, fuse connection. relay input was made, relay output was brought to the front, but the lamp connection was not made. I didn't do it because it didn't sound neutral. If I do, will it be solved?
    • #36
      Dec 2020
      españa
      16
      zafira
      Quote Originally Posted by AresUltio View Post
Name:	not reccc.jpg
      if you finish the installation.
      use the original opel black/yellow relay. (see picture of the previous message.
      check ipc and uec configuration with diagnostic machine.
      you can do use tests outside the car.
      you can use just two loose bulbs for testing.
    • #37
      Apr 2019
      İlçe
      32
      hello, I was sick, I just recovered, I couldn't control. I completed the circuit today. uec and ipc are set to "no rec". front fog programmed. I installed 2 portable lamps and it didn't work. Unfortunately, neutral does not come to the relay. There is no yellow stripe on the relay like yours. there is the one with the original code in the photo.
      code:13 266 316
Name:	Ekran görüntüsü 2023-05-26 125057.jpg
    • #38
      Dec 2020
      españa
      16
      zafira
ID:	2607Click image for larger version.
      the relay number is:
      90 508 807 yellow line.
      you can use the UEC model LZ.
      If you buy UEC or IPC you need the tents.
      you may have to change the version to use with tech2 or gm mdi.
      I send you a photograph of my tech2 and the 2 variants.
      Fog lights have to be activated in IPC and UEC.
      I can't give you the CPI model for gasoline vehicles.
      The photographs are of my Opel Zafira.
    • #39
      Dec 2020
      españa
      16
      zafira
      The photographs have been taken from my car.
    • #40
      Member vhcjuliet's Avatar
      Jul 2023
      London
      1
      Astra Mk5 1.8)
      Thank you guys for sharing useful information.
  1. Fog light
    By rbngn91 in forum Vectra
    Last Post: 13th October 2018, 07:54 AM
  2. Replies: 1
    Last Post: 4th September 2013, 12:30 AM
  3. Replies: 0
    Last Post: 3rd September 2013, 11:10 PM
vectra c fog light fuse
vectra c front fog light fuse
front fog light fuse vectra c
vectra c fog light relay
vectra c front fog light relay
astra h fog light wiring
https:www.diagnostics.org.ukshowthread.php758-Front-Fog-Lamp-wiring
astra h fog light fuse location
vauxhall vectra c front fog light fuse
zafira b fog light install without REC
vectra c front fog light relay location
https:www.diagnostics.org.ukhelpshowthread.php758-Front-Fog-Lamp-wiring
vauxhall astra h fog light wiring loomzafira b front fog lightsvectra c fog light wiring diagramphotos of astra h fog lights wiring loomastra mk5 front fog light wiringvectra c fog light fuse locationzafira fog light wiring diagraminsignia uec fog light wiringhttps:www.diagnostics.org.ukshowthread.php758-Front-Fog-Lamp-wiringpage2vectra b fog light wiring astra h fog light installationvectra c fog light wiringvectra b front fog light relay and wiring
