Results 1 to 8 of 8
    Zafira B - REC - Rear Electrical Centre
      XR1
      Pin assignment
      Pin Color Wire size Option Function
      3 Brown-Blue 0.5 Keyless Entry Antenna Low Reference (5)
      4 Blue-Yellow 0.5 Rear electronic module Lift Gate Unlatch Switch Signal
      12 Black-Yellow 0.5 Centre Position Stop Lamp Control
      16 - - Rear electronic module Park pilot (3 Connectors) -
      17 Yellow-Blue 0.5 Keyless Entry Antenna Signal (5)
      22 Black 1.5 Rear electronic module Ignition Voltage
      28 Black-Blue 0.5 Rear electronic module Lift Gate Ajar Switch Signal (1)
      29 Gray-White 0.5 Shock Sensor Signal
      31 Black-White 0.5 Left Rear Turn Signal Lamp Control
      32 Black-Blue 0.5 Rear electronic module Left Rear Fog Lamp Control
      34 White-Black 0.5 Rear electronic module Right Backup Lamp Control
      35 Gray-Green 0.5 Rear electronic module Side Marker/License Control Signal
      36 Blue-Black 0.75 Rear electronic module Fuel Door Lock/Unlock (1) Reference
      37 Blue 0.75 Rear electronic module Fuel Door Lock/Unlock (1) Signal
      38 Brown-White 0.75 Rear electronic module Lift Gate Open/Close Motor Close Control
      40 Blue 1.5 Rear electronic module Rear Window Wiper Motor Control
      41 Black-Green 0.5 Right Rear Turn Signal Lamp Control
      42 White-Black 0.5 Rear electronic module Left Backup Lamp Control
      44 Black-Yellow 0.5 Rear electronic module RT_Tail Lamp Stop Lamp PWM Control
      45 Black-Yellow 0.5 Rear electronic module Tail Lamp Stop Lamp PWM Control
      XR2
      Pin assignment
      1 Black 0.75 Rear electronic module Ignition Voltage
      4 Black 2.5 Rear electronic module Rear Defog Element Control
      XR3
Name:	XR3-ZF 30-11.jpg
      Pin assignment
      2 Red 1.5 Rear electronic module Battery Positive Voltage
      3 Red 1.5 Rear electronic module Battery Positive Voltage
      7 Gray-White 0.5 Rear electronic module Intrusion Sensor Armed Signal
      8 Red 0.5 Rear electronic module Battery Positive Voltage
      9 Red 0.75 Rear electronic module Battery Positive Voltage
      11 Red 0.75 Rear electronic module Battery Positive Voltage
      12 Red 2.5 Rear electronic module Battery Positive Voltage
      13 Red 2.5 Rear electronic module Battery Positive Voltage
      25 Red 0.5 Rear electronic module Battery Positive Voltage
      27 Red 0.75 Rear electronic module Battery Positive Voltage
      29 Red 2.5 Rear electronic module Battery Positive Voltage
      30 Red 2.5 Rear electronic module Battery Positive Voltage
      XR4
Name:	XR4-ZF 30-12.jpg
      Pin assignment
      1 Red 2.5 Rear electronic module Battery Positive Voltage
      4 Black 0.75 Rear electronic module Ignition Voltage
      6 Black 0.5 Rear electronic module Ignition Voltage
      7 Black 0.5 Rear electronic module Ignition Voltage
      8 Black 0.5 Rear electronic module Ignition Voltage
      10 Black 1 Rear electronic module Ignition Voltage
      11 White-Black 0.75 Rear electronic module Mirror Heating Element Control
      15 Black 0.5 Rear electronic module Ignition Voltage
      16 Black-White 0.5 Rear electronic module Ignition Voltage
      18 Brown 0.5 Ground
      20 Red 1.5 Rear electronic module Battery Positive Voltage
      21 Black 1.5 Rear electronic module Ignition Voltage
      XR5
      Pin assignment
      1 Black 0.75 Rear electronic module Park pilot (3 Connectors) -
      2 Yellow-Blue 0.5 Keyless Entry Antenna Signal (5)
      6 Black 0.5 Ignition Voltage
      7 Gray 0.5 Rear electronic module Interior Lamp Control
      10 Brown-Black 0.5 Open & Start Power Window Comfort Close Signal
      10 Brown-Black 0.5 Open & Start Rear electronic module Power Window Comfort Close Signal
      11 Brown-Green 0.5 Hood Ajar Switch Signal
      12 Black 0.5 -
      17 Brown-Blue 0.5 Keyless Entry Antenna Low Reference (5)
      18 Blue-Yellow 0.5 Rear Closure Handle Switch Open Signal
      19 Red-Blue 0.5 Rear electronic module Electronic Control Unit 12 Volt Reference (3)
      21 White 1.5 Open & Start Door Unlock Control
      21 White 1.5 Open & Start Rear electronic module Door Unlock Control
      22 Black-Green 1.5 Open & Start All Door Deadbolt Motor Lock Control
      22 Black-Green 1.5 Open & Start Rear electronic module All Door Deadbolt Motor Lock Control
      23 Brown 1.5 Ground
      24 Brown-Yellow 0.5 Z16YNG/Z16XNT engines Signal Ground
      26 Green-Blue 0.5 Fuel Level Sensor Signal
      27 Gray 0.5 Open & Start Right Front Door Ajar Switch Signal
      27 Gray 0.5 Open & Start Rear electronic module Right Front Door Ajar Switch Signal
      28 Gray 0.5 Open & Start Left Rear Door Ajar Switch Signal
      28 Gray 0.5 Open & Start Rear electronic module Left Rear Door Ajar Switch Signal
      29 Gray 0.5 Open & Start Right Rear Door Ajar Switch Signal
      29 Gray 0.5 Open & Start Rear electronic module Right Rear Door Ajar Switch Signal
      30 Green 0.5 Low Speed GMLAN Serial Data
      31 Green 0.5 Low Speed GMLAN Serial Data
      32 Green 0.5 Low Speed GMLAN Serial Data
      33 Green 0.5 Low Speed GMLAN Serial Data
      36 Red-Brown 0.75 Content Theft Horn Control
      37 Black-Yellow 0.5 Rear electronic module Electronic Control Unit 12 Volt Reference (2)
      38 Red 1.5 Open & Start Door Lock Control
      38 Red 1.5 Open & Start Rear electronic module Door Lock Control
      44 White-Gray 0.5 Open & Start Driver Door Ajar Switch Signal
      44 White-Gray 0.5 Open & Start Rear electronic module Driver Door Ajar Switch Signal
      46 Brown 0.5 Ground
      47 Gray 0.5 Interior Lamp Control
      48 Red-White 0.5 Intrusion Sensor Data Signal
      49 Brown-Red 0.5 Power Sounder Enable Signal
      52 Violet-Brown 0.5 Open & Start Driver Door Lock Status Indicator Signal Ground
      52 Violet-Brown 0.5 Open & Start Rear electronic module Driver Door Lock Status Indicator Signal Ground
      53 Red 0.5 Battery Positive Voltage
      55 Brown-Gray 0.5 Stop Lamp Switch Signal
      57 Black 0.75 Ignition Voltage
      58 Brown-Red 0.5 Park Brake Switch Signal
      XR6
      Pin assignment
      1 Red 10 Rear electronic module Battery Positive Voltage
      2 Red 10 Rear electronic module Battery Positive Voltage
      XR7
      Pin assignment
      1 Gray-Black 0.75 Left Trailer Park Lamp
      2 Black-Green 0.75 Right Trailer Turn Signal Lamp
      3 Black-Blue 0.75 Trailer Fog Lamp
      4 White-Black 0.75 Trailer Backup Lamp
      5 Black-Yellow 0.75 Trailer Brake Lamp
      6 Black-White 0.75 Left Trailer Turn Signal Lamp
      10 Red 2.5 Battery Positive Voltage
      12 Gray-Red 0.75 Right Trailer Park Lamp
  1. Advice on Rear Electrical Center
    By j1mmy1985 in forum Zafira
    Last Post: 11th August 2013, 10:46 PM
  2. Zafira B - UEC - Underhood Electrical Centre
    By pecky in forum Zafira B wiring diagrams and connector pinouts
    Last Post: 4th March 2012, 09:52 AM
https:www.diagnostics.org.ukshowthread.php757-Zafira-B-REC-Rear-Electrical-Centre
https:diagnostics.org.ukshowthread.php757-Zafira-B-REC-Rear-Electrical-Centre
vauxhall zafira rear electrical centre
vauxhall zafira rear light wiring diagram
zafira rec
vauxhall zafira rec
nu vot
wiring guide to rear lights on zafira bwhat coulours are lighting on a zafra brec modul pinout58 zafira reczafira with reczafira wiring diagramzafira B REC08 zafira rear rec locationrear electrical centre zafiravauxhall zafira wiring diagramrec zafirahttp:www.diagnostics.org.ukhelpshowthread.php757-Zafira-B-REC-Rear-Electrical-Centrezafira rear electrical centrezafira 2006 control moduleRear Electrical Center zafira rear reczafira b door open sensor
