Currently displaying DAB SAFE !!!!
Help !!!
At long last I've got the loom, DAB box, CDC40 and all codes.
But I've forgotten the sequence of how to add the DAB box !!!
So far I've 'divorced' the cars original old CD30 and display and removed them and have fitted the CDC40 and GID, that's it !!
Now what do I do ? From memory I now 'divorce' this CDC40 with screen and then change the variant confit to DAB active and then marry it with the DAB boxes code (which is different from the CDC40) !?!?
Help !!!
was the dab box divorced from old car?
If the code of dab box is known I would do.
unpair existing radio / screen (and whatever else, like ecc or uhp4)
change midspeed to now include dab unit.
program theft protection using dab units security code.
then clear all items, then re-pair one final time
All working superbly now
Now to sort a decent aerial
I would like to use the topic to ask about DAB and CDC40.
From what was written above I understood that you successfully set DAB to Present in MID Speed Bus configuration right?
My problem is that when I go to mid bus conf. in CDC40 and display there is no DAB option, and I cannot set it to Present....
Which year is your Astra?
