Results 1 to 4 of 4
    Zafira B - UEC - Underhood Electrical Centre
      XE1
      Pin assignment
      Pin Color Wire size Option Function
      2 Red-Yellow 4 Engine Z19DTH Air conditioning, compressor Engine Z19DT (Automatic transmission) Cooling Fan Motor Control (1)
      2 Red-Yellow 6 Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Motor Control (1)
      3 Red-White 4 Engine Z19DTH Air conditioning, compressor Engine Z19DT (Automatic transmission) Cooling Fan Motor Control (1)
      3 Red-White 6 Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Motor Control (2)
      3 Red-White 6 Engine Z19DTL Air conditioning, compressor Engine Z19DT (Manual transmission) Engine A17DTJ Z16YNG/Z16XER/Z16XE1/Z18XER/Z22YH engines Cooling Fan Motor Control (2)
      3 Red-White 6 Air conditioning, compressor Z16YNG/Z16XER/Z16XE1/Z18XER engines Cooling Fan Motor Control (2)
      4 Red-Green 4 Engine Z19DTH Air conditioning, compressor Engine Z19DT (Automatic transmission) Cooling Fan Motor Low Reference
      4 Brown-Green 6 Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Motor Low Reference
      4 White-Black 4 Engine Z19DTL Air conditioning, compressor Engine Z19DT (Manual transmission) Engine A17DTJ Z16YNG/Z16XER/Z16XE1/Z18XER/Z22YH engines Battery Positive Voltage
      4 White-Black 4 Air conditioning, compressor Z16YNG/Z16XER/Z16XE1/Z18XER engines Battery Positive Voltage
      5 Brown 4 Engine Z19DTH Air conditioning, compressor Engine Z19DT (Automatic transmission) Ground
      5 Brown 6 Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Ground
      5 Red-Yellow 6 Engine Z19DTL Air conditioning, compressor Engine Z19DT (Manual transmission) Engine A17DTJ Z16YNG/Z16XER/Z16XE1/Z18XER/Z22YH engines Cooling Fan Motor Control (1)
      5 Red-Yellow 4 Air conditioning, compressor Z16YNG/Z16XER/Z16XE1/Z18XER engines Cooling Fan Motor Control (1)
      7 White 1 Xenon light Rear electronic module Left Headlamp High Beam Control
      7 Black-White 0.5 Rear electronic module Left Front Turn Signal Lamp Control
      8 Gray-Black 0.5 Rear electronic module Left Turn Signal Lamp Control
      8 Gray-Green 0.75 Rear electronic module Right Turn Signal Lamp Control
      9 Gray-Black 0.5 Adaptive forward lighting Left Park Lamp Control
      9 Gray-Black 0.5 Xenon light Rear electronic module Left Park Lamp Control
      9 Yellow-Red 0.75 Rear electronic module Tail Lamp Stop Lamp PWM Control
      10 Brown-Black 0.5 A/C Refrigerant Pressure Sensor Low Reference
      11 Black-Blue 0.75 Rear electronic module Left Rear Fog Lamp Control
      12 Black-Green 0.5 Rear electronic module Right Front Turn Signal Lamp Control
      12 White 1 Xenon light Rear electronic module Right Headlamp High Beam Control
      13 Gray-Green 0.5 Rear electronic module Right Turn Signal Lamp Control
      13 Yellow-Black 0.75 Rear electronic module RT_Tail Lamp Stop Lamp PWM Control
      14 Gray-Red 0.5 Adaptive forward lighting Right Park Lamp Control
      14 Gray-Red 0.5 Xenon light Right Park Lamp Control
      14 Gray-Black 0.75 Rear electronic module Left Turn Signal Lamp Control
      15 Gray-Green 0.5 Xenon light Rear electronic module Side Marker/License Control Signal
      16 Green-White 0.5 Rear electronic module Windshield Washer Fluid Level Sensor Signal
      16 Brown-Gray 0.5 Rear electronic module Stop Lamp Switch Signal
      19 White-Black 4 Engine Z19DTH Air conditioning, compressor Engine Z19DT (Automatic transmission) Cooling Fan Motor Control (1)
      19 White-Black 4 Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Motor Control (1)
      20 White-Black 4 Engine Z19DTH Air conditioning, compressor Engine Z19DT (Automatic transmission) Cooling Fan Motor Control (1)
      20 White-Black 4 Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Motor Control (1)
      21 Red 4 Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Battery Positive Voltage
      21 White-Black 4 Engine Z19DTL Air conditioning, compressor Engine Z19DT (Manual transmission) Engine A17DTJ Z16YNG/Z16XER/Z16XE1/Z18XER/Z22YH engines Battery Positive Voltage
      21 White-Black 4 Air conditioning, compressor Z16YNG/Z16XER/Z16XE1/Z18XER engines Battery Positive Voltage
      23 Red-Blue 4 Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Battery Positive Voltage
      24 Yellow 1 Adaptive forward lighting Left Headlamp Low Beam Control
      24 Yellow 1 Xenon light Left Headlamp Low Beam Control
      25 White 1 Xenon light Rear electronic module Right Headlamp High Beam Control
      25 White 1 Adaptive forward lighting Right Headlamp High Beam Control
      25 White 1 Xenon light Rear electronic module Right Headlamp Low Beam Control
      27 Black 1 Ignition Voltage
      29 Black-Violet 1 Rear electronic module Rear Window Washer Pump Control
      29 Yellow 1 Adaptive forward lighting Right Headlamp Low Beam Control
      29 Yellow 1 Xenon light Rear electronic module Right Headlamp Low Beam Control
      30 Green 0.5 A/C Refrigerant Pressure Sensor Signal
      31 White 1 Adaptive forward lighting Left Headlamp High Beam Control
      31 White 1 Xenon light Rear electronic module Left Headlamp High Beam Control
      31 Black-Red 1 Rear electronic module Windshield Washer Pump Control
      32 Brown-White 1.5 Rear electronic module Low Note Horn Enable Signal
      32 Brown-White 0.75 Rear electronic module Lift Gate Open/Close Motor Close Control
      33 Brown-Violet 1.5 Rear electronic module High Note Horn Enable Signal
      34 Brown-Yellow 0.5 Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Relay Coil Control
      36 Green 0.5 Adaptive forward lighting High Speed GMLAN Serial Data (+) (1)
      37 Black-White 0.5 A/C Pressure Sensor 5 Volt Reference
      38 White 0.5 Adaptive forward lighting High Speed GMLAN Serial Data (-) (1)
      40 Black 0.5/1 Ignition Voltage
      41 Black 0.5/1 Ignition Voltage
      42 Black-Red 1 Rear electronic module Windshield Washer Pump Control
      42 White 1 Open & Start Rear electronic module Door Unlock Control
      43 Gray-White 1 Open & Start Rear electronic module Door Lock Control
      43 Black-Violet 1 Rear electronic module Rear Window Washer Pump Control
      44 Black-White 1.5 Rear electronic module A/C Compressor Clutch Control
      44 Brown-White 1.5 Rear electronic module Low Note Horn Enable Signal
      44 Brown-White 1.5 Trumpet horn, dual Rear electronic module Low Note Horn Enable Signal
      45 Blue 0.5 Outside Ambient Air Temperature Sensor Signal
      46 Black-Red - Headlamp Washer Pump Control
      46 - 2.5 Rear electronic module Headlamp Washer Pump Control
      46 Black 4 Rear electronic module Rear Defog Element Control
      47 Brown 2.5 Ground
      48 Brown-Gray 1.5 Left Front Fog Lamp Control
      48 Red-Blue 0.5 Rear electronic module Electronic Control Unit 12 Volt Reference (3)
      49 Brown-Green 1.5 Right Front Fog Lamp Control
      50 Red 1 Battery Positive Voltage
      51 Green-Red 0.5 Open & Start Rear electronic module Relay Deadbolt Lock Control
      51 Brown-Blue 0.5 Rear electronic module Rear Window Wiper Switch Signal
      52 Red 0.75/2.5 Battery Positive Voltage
      54 Blue-Brown 0.5 Outside Ambient Temperature Sensor Low Reference
      55 Red 0.75 Battery Positive Voltage
      56 Blue-White 0.5 Xenon light Headlamp Leveling Switch Bit 1 Signal
      57 Black-White 0.5 Xenon light Headlamp Leveling Switch Bit 1 Signal
      60 Brown 1 Rear electronic module Ground
      60 Gray 0.5 Rear electronic module Interior Lamp Control
      62 Blue-Brown 0.5 Rear electronic module Outside Ambient Temperature Sensor Low Reference
      62 Brown 1 Rear electronic module Ground
      XE2
      Pin assignment
      1 Black-Brown 0.5 ABS Brake Switch Signal
      2 Brown-Black 1 Diesel Rear electronic module A/C Compressor Clutch Solenoid Control
      3 White-Green 0.5 Engine Z18XER Engine Z16XER Accelerator Pedal Position Signal (2)
      3 White-Green 0.5 Z16XER/Z18XER engines Accelerator Pedal Position Signal (2)
      4 Black-Red 0.5 Engine Z18XER Engine Z16XER Accelerator Pedal Position 5 Volt Reference (1)
      4 Black-Red 0.5 Z16XER/Z18XER engines Accelerator Pedal Position 5 Volt Reference (1)
      5 Brown-Red 0.5 Engine Z18XER Engine Z16XER Accelerator Pedal Position Low Reference (1)
      5 Brown-Red 0.5 Z16XER/Z18XER engines Accelerator Pedal Position Low Reference (1)
      6 Black 0.5 Electrical power steering (TRW) Ignition Voltage
      6 Black 0.5 Electrical power steering (ZF) Ignition Voltage
      7 Brown-Red 0.5 Park Brake Switch Signal
      8 Blue-White 0.5 Electrical power steering (TRW) Generator Turn On Signal
      9 Red 0.5/0.75 Battery Positive Voltage
      10 Green-Blue 0.5 Rear electronic module Fuel Level Sensor Signal
      10 Brown-Green 0.5 Rear electronic module Low Coolant Level Indicator Control
      11 Green 0.5 Rear electronic module Low Speed GMLAN Serial Data
      12 Brown-Yellow 0.5 Headlamp Leveling Switch Bit 1 Signal
      13 Brown-Green 0.5 Rear electronic module Windshield Wiper Motor Park Switch Signal
      13 Gray 0.5 Open & Start Rear electronic module Right Front Door Ajar Switch Signal
      14 Black 0.75 Ignition Voltage
      15 Gray 0.5 Cruise Control Clutch Pedal Position Switch Signal
      16 Brown-Gray 0.5 Stop Lamp Switch Signal
      17 Black-Yellow 0.5 Engine Z18XER Engine Z16XER Accelerator Pedal Position 5 Volt Reference (2)
      17 Black-Yellow 0.5 Z16XER/Z18XER engines Accelerator Pedal Position 5 Volt Reference (2)
      18 Brown-White 0.5 Engine Z18XER Engine Z16XER Accelerator Pedal Position Low Reference (2)
      18 Brown-White 0.5 Z16XER/Z18XER engines Accelerator Pedal Position Low Reference (2)
      19 White-Yellow 0.5 Engine Z18XER Engine Z16XER Accelerator Pedal Position Signal (1)
      19 White-Yellow 0.5 Z16XER/Z18XER engines Accelerator Pedal Position Signal (1)
      20 Brown-Black 0.5 Rear electronic module Reverse Switch Signal
      22 Black-Blue 0.5 Rear electronic module Lift Gate Ajar Switch Signal (1)
      23 Brown-Green 0.5 Rear electronic module Windshield Wiper Motor Park Switch Signal
      23 Violet 0.5 Open & Start Emergency Door Unlock Control
      23 Violet 0.5 Open & Start Rear electronic module Emergency Door Unlock Control
      24 Green 0.5 Low Speed GMLAN Serial Data
      24 Brown-Yellow 0.5 Z16YNG/Z16XNT engines Signal Ground
      26 Green 0.5 Rear electronic module Low Speed GMLAN Serial Data
      26 Blue-White 0.5 Electrical power steering (TRW) Generator Turn On Signal
      27 Blue-Yellow 0.5 Rear electronic module Lift Gate Unlatch Switch Signal
      28 Brown-Red 0.5 Rear electronic module Brake Fluid Level Sensor Signal
      28 White-Gray 0.5 Open & Start Rear electronic module Driver Door Ajar Switch Signal
      29 Red 4 Battery Positive Voltage
      30 Red 4 Battery Positive Voltage
      31 Red 6 Battery Positive Voltage
      32 Black 6 Ignition Voltage
      33 Red 0.5 Battery Positive Voltage
      34 Red 0.5/0.75 Battery Positive Voltage
      35 Red 0.5 Battery Positive Voltage
      36 Red 0.5 Battery Positive Voltage
      38 Black 0.5 Ignition Voltage
      39 Black 0.5 Ignition Voltage
      40 Black 0.5 Rear electronic module Ignition Voltage
      42 Red 0.75 Battery Positive Voltage
      43 White 0.5 High Speed GMLAN Serial Data (-) (1)
      44 White 0.5 High Speed GMLAN Serial Data (-) (1)
      45 Green 0.5 High Speed GMLAN Serial Data (+) (1)
      47 White 0.5 High Speed GMLAN Serial Data (-) (1)
      49 Green 0.5 High Speed GMLAN Serial Data (+) (1)
      50 Green 0.5 High Speed GMLAN Serial Data (+) (1)
      52 Brown-Black 0.5 A/C Compressor Clutch Relay Control
      53 Brown-Black 0.5 Rear electronic module A/C Compressor Clutch Relay Control
      53 Red 0.75 Rear electronic module Battery Positive Voltage
      54 Violet-Brown 0.5 Open & Start Rear electronic module Driver Door Lock Status Indicator Signal Ground
      54 Green - Rain Sense Signal (1)
      54 - 0.5 Rear electronic module Rain Sense Signal (1)
      55 White 2.5 Windshield Wiper Motor High Speed Control
      56 Red-Blue 1.5 Z16YNG/Z16XNT engines Fuel Pump Control
      57 Yellow 2.5 Windshield Wiper Motor Low Speed Control
      59 Black 1.5 Ignition Voltage
      60 Red-Blue 0.5 Powertrain Main Relay Fused Supply (4)
      61 Red 2.5 Battery Positive Voltage
      62 Red 0.75 Battery Positive Voltage
      63 Black 2.5 Engine Z16XNT Vacuun assist pump relay
      63 Black-White 2.5 Petrol Rear electronic module A/C Compressor Clutch Control
      63 Blue-Green 0.75 Diesel Fuel Vapor Temperature
      XE3
      Pin assignment
      1 Black-Red - Starter Relay Coil Control
      2 Brown-Blue 0.5 Engine Z22YH Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Relay Coil Control
      2 White-Black 0.75 Engine Z19DTH Air conditioning, compressor Engine Z19DT (Automatic transmission) Cooling Fan Relay Coil Control
      2 White-Black 0.5/0.75 Engine Z22YH Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Relay Coil Control
      3 Brown-Yellow 0.75 Engine Z19DTH Air conditioning, compressor Engine Z19DT (Automatic transmission) Cooling Fan Relay Coil Control
      3 Brown-Yellow 0.5/0.75 Engine Z22YH Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Relay Coil Control
      3 Brown-Blue 0.5 Engine Z22YH Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Relay Coil Control
      3 Brown-Red / Red-White / Brown-Yellow / Brown-Blue - Engine Z19DTL Air conditioning, compressor Engine Z19DT (Manual transmission) Engine A17DTJ Z16YNG/Z16XER/Z16XE1/Z18XER/Z22YH engines Cooling Fan Relay Coil Control
      3 - - Air conditioning, compressor Z16YNG/Z16XER/Z16XE1/Z18XER engines -
      4 Black-Red 2.5 Starter Solenoid Crank Voltage
      5 Red 0.5 Electrical power steering (TRW) Engine Load Signal
      6 Brown-Yellow / Red-White / Brown-Red / Brown-Blue / White-Black - Engine Z19DTL Air conditioning, compressor Engine Z19DT (Manual transmission) Engine A17DTJ Z16YNG/Z16XER/Z16XE1/Z18XER/Z22YH engines Cooling Fan Relay Coil Control
      6 Brown-Yellow / Red-White / Brown-Red / Brown-Blue / White-Black - Air conditioning, compressor Z16YNG/Z16XER/Z16XE1/Z18XER engines Cooling Fan Relay Coil Control
      6 Brown-Blue 0.5 Engine Z22YH Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Relay Coil Control
      6 Brown-Red 0.75 Engine Z19DTH Air conditioning, compressor Engine Z19DT (Automatic transmission) Cooling Fan Relay Coil Control
      6 Brown-Red 0.5/0.75 Engine Z22YH Z20LER/Z20LEH engines Engine Z22YH with air conditioning, compressor Diesel engines with air conditioning, compressor Engine Z16XNT Cooling Fan Relay Coil Control
      7 - - -
      8 Yellow-Red 0,5 A/C Refrigerant Pressure Sensor Signal
      9 Red 0.5 Park Brake Switch Signal
      10 Black-White 0.5 A/C Pressure Sensor 5 Volt Reference
      11 Blue 0.5 High Speed GMLAN Serial Data (+) (1)
      12 Red 0.5 Open & Start Rear electronic module -
      12 Red 0.5 Rear electronic module Rear Window Wiper Switch Signal
      13 Brown-Red 0.5 Z16YNG/Z16XNT engines Fuel Pump Primary Relay Control
      13 Brown-Red 0,5 Z16YNG/Z16XNT engines Fuel Pump Primary Relay Control
      14 Brown-Violet / Brown-Red - Rear electronic module A/C Compressor Clutch Solenoid Control
      14 Red 0.5 Rear electronic module Lift Gate Ajar Switch Signal (1)
      15 Green 0.5 High Speed GMLAN Serial Data (-) (1)
      16 Brown-White 0,5 Engine Main Relay Coil Control
      17 Red 4 Battery Positive Voltage
      19 Red 0.75 Battery Positive Voltage
      20 Red 0.5/0.75 Battery Positive Voltage
      21 Black-White 0.75/BK 1.5 Ignition Voltage
      22 Black 0.75/1.5/2.5 Ignition Voltage
      23 Black / Red 0.75/1.5 Ignition Voltage
      24 Black-Red 0.5 Starter Relay Coil Control
      25 Brown-Violet 0.5 Petrol Rear electronic module Z16XER/Z18XER engines A/C Compressor Clutch Solenoid Control
      25 Brown-Red 0.5 Engine Z16XNT Engine Z16XNT Run/Crank Ignition 1 Voltage
      25 Brown-Red 0.5 Petrol Rear electronic module Engine Z16XE1 A/C Compressor Clutch Solenoid Control
      25 Blue-Green 0.5 Diesel Heater Fuel Control
      27 Gray 0.5 Z16XER/Z18XER engines Cruise Control Clutch Pedal Position Switch Signal
      27 Black-Yellow 0.5 Z16XER/Z18XER engines Cruise Control Clutch Pedal Position Switch Signal
      28 Red-Blue 2,5 Powertrain Main Relay Fused Supply (1)
      29 Red-Blue 2,5 Powertrain Main Relay Fused Supply (2)
      31 White-Black 0.75 Z16XER/Z18XER engines Reverse Switch Signal
      31 Gray 0.5 Open & Start Rear electronic module -
      31 Red 0.5 Rear electronic module Rear Window Wiper Switch Signal
      31 Black-White 0.75 Automatic transmission (AF22/4) Reverse Switch Signal
      31 Black-White 0.75 Z16XER/Z18XER engines Reverse Switch Signal
      32 Brown-Black 1.5 Z20LER/Z20LEH engines Z16YNG/Z16XNT engines Fuel Injection Control
      32 Brown-Black 1.5 Z16YNG/Z16XNT engines Fuel Pump Control
      32 Red-Blue 1.5 Z16YNG/Z16XNT engines Fuel Pump Control
      32 White 1.5 Z20LER/Z20LEH engines Z16YNG/Z16XNT engines Fuel Injection Control
      33 - - -
      34 Brown-Red 0.75 Diesel Rear electronic module A/C Compressor Clutch Solenoid Control
      35 Black-Yellow 0.5 Z16XER/Z18XER engines Accelerator Pedal Position Signal (2)
      35 White-Green 0.5 Engine Z18XER Engine Z16XER Accelerator Pedal Position Signal (2)
      36 Black-Red 0.5 Engine Z18XER Engine Z16XER Accelerator Pedal Position 5 Volt Reference (1)
      36 Black-White 0.5 Z16XER/Z18XER engines Accelerator Pedal Position 5 Volt Reference (1)
      37 Brown 0.5 Z16XER/Z18XER engines Accelerator Pedal Position Low Reference (1)
      37 Brown-Red 0.5 Engine Z18XER Engine Z16XER Accelerator Pedal Position Low Reference (1)
      38 Red 0.5 Electrical power steering (TRW) -
      38 Red 0.5 Electrical power steering (ZF) -
      39 Red 0.5 Park Brake Switch Signal
      40 Red 0.5 Electrical power steering (TRW) Engine Load Signal
      41 - - -
      42 Black-White 0.5 Z16XER/Z18XER engines Accelerator Pedal Position 5 Volt Reference (2)
      42 Black-Yellow 0.5 Engine Z18XER Engine Z16XER Accelerator Pedal Position 5 Volt Reference (2)
      43 Brown-White 0.5/0,75 Engine Z18XER Engine Z16XER Accelerator Pedal Position Low Reference (2)
      43 Brown 0.5 Z16XER/Z18XER engines Accelerator Pedal Position Low Reference (2)
      44 Black-Yellow 0.5 Z16XER/Z18XER engines Accelerator Pedal Position Signal (1)
      44 White-Yellow 0.5 Engine Z18XER Engine Z16XER Accelerator Pedal Position Signal (1)
      45 Black 0.75 Rear electronic module Reverse Switch Signal
      47 Red 0.5 Rear electronic module Lift Gate Ajar Switch Signal (1)
  1. Zafira b electrical problems
    By jetsmike73 in forum Zafira
    Last Post: 14th February 2014, 11:21 PM
  2. Zafira B - REC - Rear Electrical Centre
    By pecky in forum Zafira B wiring diagrams and connector pinouts
    Last Post: 4th March 2012, 10:15 AM
earth points zafira b
Zafira uec pinout
zafira b fuel pump relay location
zfw 63-1
https:diagnostics.org.ukshowthread.php756-Zafira-B-UEC-Underhood-Electrical-Centre
zafira B water in UEC
zafira b uec
zafira relay diagram
vauxhall uec pinouthttps:www.diagnostics.org.ukshowthread.php756-Zafira-B-UEC-Underhood-Electrical-Centrezafira b relay diagramunderhood electrical centre vauxhall zafira 2001zafira air con relayzafira b relay locationszafira UEC clutch switchzafira cooling fan relay locationwhere is the underhood electrical centre on my zafira uec zafira bvauxhall zafira wiring diagramzafira uecmk1 zafira relay diagramzafira b rear wiper schematicsopel zafira b indicator relay locationvauxhall zafira engine diagramzafira relay locations
