Hi guys after some advice regarding a BCM on a 2012 Corsa VXR Nurburgring.
I have one in at the moment and 99% sure the BCM is faulty. Have the ABS light and Traction light on. Fault codes on the ABS are:
-Wrong Variant config installed
-No communication to SAS
I have calibrated SAS and variant config is correct and this is a brand new ABS pump installed.
Now the BCM has fault codes:
-No communication with ECM
-No communication with ABS
When I try to go into it with Tech 2 it says something along the lines of no modules found for this car or something along those lines (can access all other modules).
I know this car was jump started and ever since then the issues occurred. Anyone have any ideas? Can BCM eeproms be repaired or uncorrupted?
Cheers
Gary
