I've just bought a DAB45 box with code and loom but I've just pulled out my CDC40 and it's says 'AUX' on the lid and NOT DAB !!!!
Am I stuffed ????
Am I stuffed ????
It's CDC40 number 13190750 ident TB Delphi Grundig if that helps ?
same difference mate, you will be fine as it uses the aux input to transmit the audio through
Cool
I just couldn't find anything in the programming of the CDC40 that enabled DAB as a function.
Unless it just detects that there's a DAB box fitted ?
that would be under variant config of the radio, although i may recall something about some cdc40's not having dab?
All my one comes up with is 'with AUX' or 'without AUX' !!
that is when setting code index surely? not variant config?
I've PM'd you mate
