Results 1 to 3 of 3
    Member Luke_2396's Avatar
    Jul 2017
    Wednesbury
    4
    Astra Mk5 1.4
    Vauxhall Astra MK5 1.4 Cruise Control
    Hope this is in the right place
    I purchased the clutch switch and cruise control stalk. Ive fitted the stalk, I've read that I need to put the wiring in for the switch, I was wondering if there is anyone that could do this for or tell me how to do this and what I need for the connections.
      Member Patc's Avatar
      Jan 2017
      Ireland
      3
      Astra mk5
      Quote Originally Posted by Luke_2396 View Post
      Hi. Have you looked for the clutch switch wires plug? After reading a lot online, i followed the advice and looked for it behind the instrument cluster, neatly taped up and waiting to be used. I easily routed it down and plugged it into the clutch switch. I then had cruise control enabled via tech 2 and job done.
      Jul 2017
      Wednesbury
      4
      Astra Mk5 1.4
      I read that the 1.4 doesn't come with the wiring but I will check, thanks
  1. Replies: 2
    Last Post: 8th March 2017, 07:43 AM
