Results 1 to 10 of 16
Thread: DDS retrofit
    Member nicos's Avatar
    Dec 2016
    Liege
    96
    ASTRA TWINTOP 1.9 CDTI 200HP
    DDS retrofit
    Hello everybody.
    I would like to retrofit only DDS fonction on my ipc instrument.
    Retrofitting all TPMS cost a lot.
    I have the correct ABS pump and my car is already equipped with ESP .
    I have retrofit 6 buttons console with the DDS button.Click image for larger version.
    With Opcom i activate in IPc variants configurations "Dds enable"
    When ignition is on in my ipc instrument i have the dds light check on for 2 sec.It seems to be correctly activated on my ipc.But when i put on the button dds to reset system in my ipc the dds light dont flash as it must to do.
    So my question is what else i have to activate so dds system works correctly?
      Dec 2016
      Liege
      96
      Anybody has done this?
      You need to check the canbus networks as well as it needs to be set present across all modules on that network.
      It is on Low Speed Canbus I recall.
      Dec 2016
      Liege
      96
      Witch canbus and witch modules?How can i enter on canbus network ?
      Dec 2016
      Liege
      96
      Ok anderstand. I think you mean "Program low speed can bus configuration "
      But witch modules?All?
      I already have done ipc module.
      On Abs there is nothing to do with opcom.There is only high speed and program variant configuration change only variant coding.
      Dec 2016
      Liege
      96
      Do you think with tech2 is possible?
      Member flexeh's Avatar
      Sep 2015
      West Midlands
      26
      Zafira B z19dth
      My DDS doesn't seem to work lol I do the usual hold the button down after tyre pressures have been done but never seen it ac I ate.
      Came on my car as standard
      Member n0tiert's Avatar
      Aug 2016
      Frankfurt
      129
      Astra H
      check the ABS you need to add DDS there, also check if wire from Hazard to IPC is present
      Hazard Switch -> IPC
      Black-Brown #4 -> Black-Brown #39
      Astra H Caravan Z14XEP 18" OPC Line Rims
      https://www.astra-h-forum.de/t/mein-roter-rebell.122867/#post-3363845 My Mods
      Dec 2016
      Liege
      96
      I have try with opcom on abs module but it has not this option.I have buy a tech2 china clone to do this but tech2 not connect to the vehicule via candi module.Chinesse shit.I m trying to solve this issue connection with tech2
      Aug 2016
      Frankfurt
      129
      Astra H
      What type of ABS you got ?
      some doesn´t have the feature
      (Source: astra-h-forum.de)
      check here, i´ve retrofitted mine few weeks ago
      ABS Type: BR / YAW RATE Sensor: BA
  1. Meriva B, DDS then TPMS.. wiring
    By gazz292 in forum Electrical
    Last Post: 15th April 2018, 05:05 PM
dds retrofit astra h
dds astra h
tpms and dds retrofit
activare dds Opel Astra h opcom
astra h dds retrofit
https:diagnostics.org.ukshowthread.php7429-DDS-retrofit
