This is my ABS
System name: ESP MK60
Hardware number:16054000
Part Number:13246535
Do you think its not possible?
This is my ABS
Hello n0tiert,
I have installed ABS pump with ident AS as a part of my ESP retrofit project.
In the table shown I'm seeing it is supporting function HBA - Hydraulic Brake Assistant.
Do you know how to enable/test if it is working?
Regards,
Did you reprogrammed it to your car Specs and did you also changed the yaw rate Sensor compatible to the AS? Else it might not work.
HBA depends in car Speed and Brake pressure, i dunno how to Test it, maybe on a Supermarket Parking Place
Rgds,
n0tiert
Astra H Caravan Z14XEP 18" OPC Line Rims
https://www.astra-h-forum.de/t/mein-roter-rebell.122867/#post-3363845 My Mods
So I have programmed high speed can-bus on the ABS pump, however I'm not sure what else should I program. How to change YAW rate sensor to be compatible with AS ABS pump? From where can I reach YAW sensor programming options?
To be honest I'm not quite sure how to proper program and activate ESP option.
Cheers,
Nikolay
You should have taken it from donor car where you have the ABS from.
Not all Sensors/ABS are compatible with each other.
ABS needs to be Programmed in the Variant config and VIN.
And you have to recalibrate the YAW Rate Sensor by having the Car Standing fully straight/flat ground
