Can someone help me with a pincode for this Vectra C GID?
93s66
thank you very much
vectra c ph97cmr.rar
93s66
thank you very much
dont think you can get code from this.... What radio was it matched to and what year car?
i don't know what radio was. I need the pincode to pair a new key
what year car was it from? as early cars did not have pin code on the display
2003 I think
early cars like that didnt have pin code in radio it was on the radio only, and that code was different to the cars immobilizer code anyway
it was only the ncdc's which paired to the screen back then
the dump is not from the radio. Is from the info display. And the info display must have the same pin with the immo. I know that the radios don't have the same pin as immo..
as I said mate, the very early display did NOT have pin in the display, you could swap them around the cars very easily... Also the radio code was different to the immo code, so even if there was apin in the display then it would not be the same as the immo..
ok. then can I read the eeprom from instrument cluster at this model? does it have the pin stored in it?
