Results 1 to 3 of 3
Hybrid View
    Member Fatheed75's Avatar
    Apr 2017
    Perth
    2
    Astra mk5 2.0 turbo sri
    Astra afl problem
    Hi guys. First post on the forum so hello. I have a 2005 5 door astra h 2.0 turbo sri. It's got afl lights fitted from standard and has developed a problem with the lights. The lights are working but the annoying warning light is now flashing. I've used op com and it displays fault code b1461-00 which, after researching the web, seems to be the front left. I stripped the light out yesterday and all appears visually fine. Heres the question...... i know nothing about these lights. I know theres a ballast module, a balancing module, control module and range adjustment motor within the light. Before I start hacking the light to bits to replace the adjustment motor, does anyone know if the b1461-00 refers to a specific faulty module? If this has been asked before, i apologise. Any help appreciated as it's really frustrating not being able to diagnose the problem myself (and not very professional driving around with masking tape on the instrument cluster) thanks
  2. #2
    1,367
    Its referring to the Left hand dynamic curve light.. Most probably stuck motor...
    there are only two error codes with 1461 I can see.. One is stepper motor circuit malfunction and the other is Light Stuck..
    hope this helps
  3. #3
    Apr 2017
    Perth
    2
    Thanks for that. I've looked at you tube and seen it's possible to replace the motor (hacking into the rear of the light) any ideas where I can buy a new 1? A few used on eBay but if I'm doing it I want to do it once.
  1. AFL connectors
    By James Dennis in forum AFL Headlights
    Last Post: 5th April 2019, 09:40 PM
astra h afl fault
