Results 1 to 7 of 7
    Member alnmoore's Avatar
    May 2017
    Kidderminster
    3
    Astra H CDTI
    Help. CD30 to CD70 conversion
    Hello
    i was hoping somebody could help me: I have an Astra H 1.7 cdti 2006
    I want to upgrade form my CD30 with a GID (Blue) display which Pecky kindly fitted for me years ago. I have just bought a CD70 and CID (24461297 QN) for a Vectra C 1.9 2004 from ebay. They are married and work but when I come to use OP-COM to change the fuel etc the software doesn't communicate with the units. Can any body help or have I wasted my money by not doing the proper research?
    Regards
      1,338
      refit the cd30 and gid, does it communicate then? if no you have an issue with opcom... if it works refit the cd70 or gid (one at a time) and try to communicate.. There is no reason why it should not communicate with the new radio and screen
      Dashworx Conversions Gav's Avatar
      Nov 2013
      Bristol
      285
      Zafira Tourer & Corsa D
      The vectra cid is different to the astra h one, the size is different plus the firmware
      Gav
      May 2017
      Kidderminster
      3
      Astra H CDTI
      Thanks I have managed to get to fit. Just not able to communicate to change with op-com. As you say the firmware may be different.
      1,338
      the radio is definitely the same and should communicate and so should the display as I fit them to the test rig on the workbench without any issues.. Ive also pulled out a radio and display from an Astra and fitted on the bench without any issue (set up for a vectra)
      1,338
      Quote Originally Posted by alnmoore View Post
      You will encounter issues with fuel / range / and also engine temp as well
      May 2017
      Kidderminster
      3
      Astra H CDTI
      Thanks I have issues with fuel but never had engine temp.
  1. CD30 MP3 - Somehow damaged during LED conversion
    By leeumdee in forum Infotainment - ICE - In Car Entertainment
    Last Post: 27th October 2016, 08:50 PM
  2. Swap cd30 and tid to cd70 and cid
    By Aaronipswich in forum Infotainment - ICE - In Car Entertainment
    Last Post: 27th May 2015, 01:19 PM
  3. cd30 to cd70
    By redbull360 in forum Zafira
    Last Post: 17th October 2013, 09:05 PM
astrah opcom replace cd30 with cd70
