It is confusing that status has been used on the first MoT and then the 2nd has no mention of the top mounting.
If the steering doesn't feel right either, then if I am honest, for the £29 you can get MoT tests done for, I would try and get one done again, if it fails for the reasons cited on the first one, then I would look at rejecting the car and taking it up with VOSA ref the test centre that passed it.
Clearly if it comes back as passed again, then it may be OK.
Loud growling is the wheel bearing, mine went and the noise was horrendus. Track rod end would be more a knocking noise I would have thought. If the wheel bearing has gone I would expect an MoT to pick it up as once the car is in the air you can rotate the wheels and detect a knackered bearing.
