Results 1 to 10 of 16
    Member pault's Avatar
    Mar 2017
    Bristol
    8
    Astra Vxr Burg
    Interior light fault
    Hi looking for some help into a issue i have....
    my interior lights work when turned on manually ie by each switch on the light. But they do not work when you open the door or unlock the doors, it is a Nurburgring edition with keyless entry.
    we have removed the door switch /lock and this is working fine and locks as it should.
    What connects the interior lighting to the door lock is it the door module (part number 13191677) or the door handle itself.
    Any help in resolving would be appreciated as its bugging me now lol
      Its easy to check open each door one by one and check light on dadhboard if it shows doors open warning than doors has nothing to do with it. Than its down to uec
      Mar 2017
      Bristol
      8
      Astra Vxr Burg
      Hi
      Thanks for that it was a great help, when opening the doors the door open light does come on on the dashboard.
      My next question is what is a UEC odd did you mean ecu?
      And any idea where I go from here now we have eliminated the doors as the fault ?
      Uec is fuse box under bonnet. Check for any signs of water
      Mar 2017
      Bristol
      8
      Astra Vxr Burg
      No water ingress bud, car is kept garaged and has been for 2 years.
      I will check everything in the fuse box as I inherited the problem when I bought the car but it was kept outside by its previous owner.
      Sent from my SM-G920F using Tapatalk
      Well if we can rule water out, than it can be couple of things uec still getting faulty, cim on its way out, or just something with coding.
      Mar 2017
      Bristol
      8
      Astra Vxr Burg
      The cim was replaced under warranty but can't remember if I had another issue which was cim related.
      If I source a new cim will it need re programming?
      Yes it will need
      Mar 2017
      Bristol
      8
      Astra Vxr Burg
      OK
      Thanks for all your help sir you have been very helpful.
      Just while got on mind does they stopped working sudenly or after cim was replaced?
  1. Replies: 0
    Last Post: 5th December 2016, 02:26 PM
  2. Zafira front interior light diagram
    By Dylan_bhafc in forum Zafira
    Last Post: 19th September 2013, 08:20 AM
  3. Interior light?
    By RyanWWFC in forum LED Conversions
    Last Post: 7th September 2013, 11:21 AM
  4. Fault codes P1109 and P1110, emission light on
    By kristapsl in forum Zafira
    Last Post: 21st March 2013, 05:37 PM
