Im bit more to uec fault, but must check wiring first if my memory doesnt lie me than door open signal goes to uec.
I don't know as the fault was there when I bought the car.
I will ask the original owner and find out
Sent from my SM-G920F using Tapatalk
Ok find it out first than we can work from that info
After the cim was modified and not replaced by vauxhall the lights were working.
An intermittent fault of the horn not working when the lights were on is why it went to vauxhall. The interior lights were working then....
They only stopped working when the original T5 bulbs were replaced with led versions.
There is also led bulbs in the number plate lights and side lights
Ah check them than, needs to be can bus safe ones when you try to switch them all on does it cuts out?
Does what cut out bud ?
The other lights on the number plate?
