I have purchased some speedo's with needle sweep (for Vaux Zafira 2010 diesel) all works fine but my Parking Assist doesn't work since installing the speedo's I get 2 error codes in IPC B0967-05 and B0968-02
Then in PAS settings I get code U2107-08. If I clear this one PAS works but the LED on button doesn't, it then stops working when ignition is turned off and back on.
I have set present in IPC in low speed can and prog variant, also in PAS settings to present. (PAS works fine when old speedo's put back in.
Is there something I'm missing !!!
