Can't think of anything immediately if you have looked at the low speed can as well as the variant config.
I have purchased some speedo's with needle sweep (for Vaux Zafira 2010 diesel) all works fine but my Parking Assist doesn't work since installing the speedo's I get 2 error codes in IPC B0967-05 and B0968-02
Then in PAS settings I get code U2107-08. If I clear this one PAS works but the LED on button doesn't, it then stops working when ignition is turned off and back on.
I have set present in IPC in low speed can and prog variant, also in PAS settings to present. (PAS works fine when old speedo's put back in.
Is there something I'm missing !!!
Yep low speed and variant config all set to present, could it be the clocks ?
Have you done a side by side comparison of every setting on these?
It does sound like it could be dropping comms to the PAS from that error code.. just strange how nothing else is reporting low speed can issues
on what settings (every setting example ipc pas rec uec) ?
not looked at what there are on them clocks...
if that was me.. I would check all setting on the clocks of your originals, then compare to the new ones... including manufacturing dates / software dates as there does seem to be a conflict somewhere
It could be a compatibility thing, also it may depend on if whoever did the sweep programming only changed the minimal amount of info necessary or went OTT with the changes.
Cheers guys will go and compare old with new clocks, then go from there....
Not compitable speedo
Sent from my HTC One M9 using Tapatalk
