hi Edopcburg
Can you solved your problem??
I have the same problem.
Yes they are Andy's instructions all right, the only thing that has not been checked is the actual wiring in the CU clip. I did extend the loom as it left me 4 inch's short and I have them connection correct. I may try swap them around and see if that changes anything, just incase they are wrong in cu end.
Thanks guys
hi Edopcburg
