No worries.
Sent from my iPhone using Tapatalk
No worries.
14 Zafira Tourer Techline FULLY LOADED
VAUXCOM UPA USB AUTODATA TOLERANCE AVAILABLE IN BRISTOL AND SOUTHWEST
@Gav,
Do you still remember which size iso pin you used? I was pretty sure my 1.4mm (tip) (2,0 x 2,4mm body) pins fitted... but they didn't somehow the body was too wide.
My Opel dealer swapped the "front fog lights" option to "available" in the IPC variant configuration (before I pulled the wires), after that I lay all wires and hooked up the relay and pressed the fog light button... but the ground doesn't switch on So I pulled a wire straight from the same pin to the battery's negative, result; the relay clicked and the fog lights went on... so it seems the issue is the IPC itself.
There's one thing I noticed though, we had program the IPC twice because the first time the option wasn't persistent. I'm kind of afraid the option is back to unavailable, but since I don't have Tech2 or Opcom I can't check... is there any reason why an option in the IPC keeps reverting to the default value?
By the way, this model doesn't need a suitable UEC to support front fog lights (see > https://www.diagnostics.org.uk/help/...og-Lamp-wiring and http://astra-3.pl/tip-astra-h-fuses-...compartment#up)
