does anyone have the idle control valve connector pin outs and voltages and or a wiring diagram for this and the ecu or a link i can get it please no pay sites dont have much cash
thanks
stu
thanks
stu
Hopefully this may help, the attachment has the full size version
A6 Control unit - Simtec Y4 Solenoid valve - Exhaust gas recirculation B12 Sensor - Coolant temperature Y5 Solenoid valve - Tank ventilation B30 Sensor - Knock control 1 Y6 Solenoid valve - Intake manifold B34 Impulse sensor - Crankshaft Y9.1 Injection valve - Cylinder 1 B35 Sensor - Camshaft Y9.2 Injection valve - Cylinder 2 B44 Sensor - Oxygen, exhaust, heated 1 Y9.3 Injection valve - Cylinder 3 B46 Air mass meter Y9.4 Injection valve - Cylinder 4 K16 Relay - Fuel pump Y29 Throttle valve - Positioner T1 Ignition coil - Direct ignition
