Regarding check control, do you have all wiring and sensors in place? Otherwise it will be annoying all time showing check that and that
Thats what i got forgot to make a photo of RGB cable
Thank you it's more than I want to spend, im more after geting rid of my bid screen to a gid or cid , so I have checked control like my other vxrs , fort the cd40 USB would be quite cool it's out of a late corsa , you can get for Astra but not in uk Europe only
I haven't put one in for washer bottle yet , bit worried as it came up check control not available
you might have to step the code index up by one... not 100% on the astra / zafira range of screens...
Yea my check control is not available with my bid screen is this normal
https://www.diagnostics.org.uk/help/...d-info-Display
check your existing code index against the list
Thank you how you know what code to use thanks Peter
