check to see what yours is first..
Thank you soul man is it number of the back I need
you need to use opcom/vauxcom or tech2 to go to the code index section under programming...
That photo looks like isnt from screen is it?
Enable it in dis and you will get bulb warnings, uec is for coolant and washer but opcom can mess it up so be carefull using it as it can corrupt data
Are see if some one can tech 2 it in essex
If opcom already messed something up than tech2 wont help only option than is to write same ident dump in eeprom and only than tech2
But give tech2 a try first
Yea I haven't been able to do anything with opcom as check control comes up unavailable and won't let you change it , was able to activate climate control
