Did you checked behind speedo?
If its not in there than you will need to wire one up
Sent from my HTC One M9 using Tapatalk
I've today tried fitting CC to a customers Zafira B, however despite looking everywhere I can't find the clutch switch wiring, its a 1.6 poverty spec, do I need a connector and loom to connect to the UEC?
Thanks in advance for any help you can provide.
Nothing there, anyone know where to buy the connector and pins?
Visit scrapyard and pull them out from vectra c
This way you will get connector and other end with pins too
Most of c vectras has cruise control
Zafira b x16xel? This engine have analog throtle.
As far as i know none of zafira b has throtle controled by cable, as they got resistance accelerator so not sure where you have seen analog or mechanical throtle
As far as I know X16XEL is from vectra b Zafira a or astra g from 1997 till 2000
