Results 1 to 7 of 7
    Member ryanje2's Avatar
    Dec 2016
    Stockport, Manchester
    3
    Vauxhall Astra Mk5 1.6
    Approximate cost
    Hi all, new to this forum malarkey. Just wondering if anyone knows the overall cost of getting my 07 Astra H BC Button activated and cruise control being fitted? Parts and labour? I would think I also need a car pass thing.
      For cruise control parts you are looking at around £45
      If you got right screen bc can be activated same time as cruise control gets programmed
      Security code extracting can be bit more expensive if radio and screen has been replaced if not than its quite easy task takes couple of minutes
      By profile you got 1.6 petrol there can be missing wires in wiring what can add extra costs
      Programming costs are depending from place where you go to get it done but can say starting from £30 to get it properly done
      Dec 2016
      3
      Thanks domtorredo!
      Also, does having an aftermarket head unit effect this process? It isn't just a random one, it's a 7" double din head unit like an eonon but not that make.
      As far as i know yes, not saying it can be done 100% as i never had to do it without original radio, but can try it for you tomorrow
      Dec 2016
      3
      Sounds good thanks a lot!
      Ah bit wrong i meant it should not effect
      Will check it out for you tomorrow
