Results 1 to 10 of 17
    Member willbro's Avatar
    Jul 2016
    Stoke On Trent
    13
    Insignia SE 2.0 CDTI 160BHP
    insignia 2013 gear jumping clocked
    hi
    I bought a insignia about 3 months ago and it is now jumping out of second gear so got it booked in the local gear box specialist.
    I've had other problems with the dealer I bought it from like not providing the service history I was promised and the car has only done 35k miles
    I'm now worried that the car may be clocked due to low milage and gearbox going and the other issues I've had with the dealer.
    I'm just starting to get a bad feeling about the dealer I bought from and the car.
    is there anyway to check if the milage has been clocked ?
    would they have just had to rewrite bcm or would they have had to change clocks aswell ?
    any advice is really apreshiate as I'm having a nightmare since buying the car
      Member jetsmike73's Avatar
      Feb 2011
      crewe
      52
      Insignia 20cdti navi
      Its a problem they have but they dont tell you unless you complain mine did and still does even after 3 trips under warranty
      Sent from my SM-G930F using Tapatalk
      Feb 2011
      crewe
      52
      Also the 2013 can have other electrical problems vauxhall cant fix dont know if its alll or just the ones with the intelilink 900 radios like mine
      Feb 2011
      crewe
      52
      I see your from stoke which dealer did you goto
      Jul 2016
      Stoke On Trent
      13
      Hi
      I didnt buy it from stoke i bought it from liverpool shouldnt have bought it maybe but its to late now.
      Does your do the same thing then as soon as you put it in second it jumps straight out with a bang ?
      It is booked in for Monday at a local gearbox specialist so will update here after they have striped it down and found the problem.
      This should not be happening on a car that has only done 35k it is a joke
      Mileage can be changed in the BCM over OBD with the right tool, so quite easy to clock. There is a step on MDI when programming the BCM when it says it is checking the mileage I noticed when doing things like TPMS, although it skips that step as not necessary. Not sure what it checks against, so it may be possible with a bit of digging to see if it has been or not.
      My 2012 2.0 is on 156K now and not had an issue at all with the gearbox, unless you have the lower powered 2.0 which comes with the dreaded M32, in which case it may well be the bearings.
      Feb 2011
      crewe
      52
      Mines a 20 cdti 140bhp it does it when you put it in second it woild feel like it was in gear but if you pushed harder on the leaver it went a bit further and went in gear if you didnt push it that bit it would jump out there was a repair for it but mine did exactly the same straight out of the garage on the way home and still does. I had an astra van with the m32 box and the 6th gear bearing went as you put your foot down the leaver would move backwards and forwards
      Feb 2011
      crewe
      52
      Im having loads of trouble with the radio and dash playing up some problems vauxhall have admitted to and say there is no cure and only effect my14 vehicles
      Feb 2011
      crewe
      52
      Quote Originally Posted by willbro View Post
      Hi
      Take it its just out if manufacturers warranty
      Jul 2016
      Stoke On Trent
      13
      thanks for all the reply
      it's going in garage tomorrow so will keep everyone updated.
      mine is the f40 I think as I have the 160bhp version.
      it is still under warranty but not manufacturers warrenty it has the rac warrenty run by the warrenty group where they pay the first 1k.
      after it is all fixed I am going to track down previous car user as there is address in the sat nav and ask them the mileage the car had and try get someone to check with mdi if someone has used xtool or simular to change mileage on bcm and hopefully the millage has backup somewhere.
      also if I take v5 into main dealer they can activate myvauxhall where I can see service history if it was done at vauxhall so that is worth a go.
      then if I find out it has been clocked I will take them court but even if they don't provide service history may take them court and argue the car is worth less without it
      Thanks for Input everyone
  1. Gearbox jumping out of second?
    By jetsmike73 in forum Insignia
    Last Post: 28th August 2016, 06:25 PM
  2. Cruise Control not working in 6th gear!
    By Nova_Turbo in forum Cruise Control
    Last Post: 14th February 2016, 12:03 AM
  3. Gear stick movement in 1st
    By Marv Owens in forum Mechanical
    Last Post: 21st February 2014, 07:42 AM
  4. replacing zafb 1.8 MTA gear knob
    By Bertman in forum Zafira
    Last Post: 15th August 2013, 10:28 AM
  5. VXR Gear Stick/ Turbo Shifter
    By M_Blue in forum Interior
    Last Post: 21st September 2012, 08:30 AM
