Does this VXR speedo 13216708 Supports needle sweep out of the box?
And can it bei switched from Miles to Km/h ?
Rgds,
n0tiert
Rgds,
n0tiert
Astra H Caravan Z14XEP 18" OPC Line Rims
https://www.astra-h-forum.de/t/mein-roter-rebell.122867/#post-3363845 My Mods
It appears that this speedo is used in earliest Astra models (starting 2005). It might not support it. The best way to clarify this is described by Pecky here:
https://tech2.guru/Vauxhall/project/...-astra-zafira/
is there a way to reprog VXR MPH to KMH ?
Dials can be changed as i seen, but what about mileage/kilometer
i think i found a working 13230601 WC
I've pulled the vectra eprom to pieces and know where mostly every scrap of info is stored, except for the km / miles! Once I've located it it should be pretty much the same across the range...
It cannot be done by reprogramming, its something inherent to the eprom... Can you not flash the bin file from a VXR for the EU on to the clocks to solve the issue?
Well which one you prefer then, you have one handy then I could give it a try, talked to lockwood already to keep the vxr style dials with kmh
Change country variant and see than if anything changed in eeprom
Why you didnt go for opc clocks? In eu they got opc in GB vxr
Coz all the people going for opc, vxr fits better to my car color, than blue...
