Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Hybrid View
    Member gc1967's Avatar
    Oct 2016
    Bedford
    97
    Vauxhall combo 1.3 cdti - 2008
    Fitting cruise control
    I have a vauxhall combo van 1.3 cdti and on opcom it's classed as a corsa c
    I have checked with opcom and clutch and 2 brake switches work.
    I have obviously got to find a corsa c cruise control stalk and run a wire from stalk to the bcm
    Does anyone know what wire and connectors I need and once wire is fitted and activated with opcom will it just be the matter of pushing button on replacement stalk for cruise control to kick in
    If anyone has a how to showing how to fit the wire it would be much appreciated
    Many thanks in advance
  2. #2
    Oct 2016
    Bedford
    97
    Anyone please
  3. #3
    Member n0tiert's Avatar
    Aug 2016
    Frankfurt
    129
    Astra H
    @BCM use pin 2
    *taken from Corsa !
    may you need to add another wire to engine ecu connector
    Astra H Caravan Z14XEP 18" OPC Line Rims
    https://www.astra-h-forum.de/t/mein-roter-rebell.122867/#post-3363845 My Mods
  4. #4
    Oct 2016
    Bedford
    97
    How will I know if I need to add another wire to the engine ecu connector
  5. #5
    Aug 2016
    Frankfurt
    129
    Astra H
    If its less MJ04
  6. #6
    Oct 2016
    Bedford
    97
    Quote Originally Posted by n0tiert View Post
    If its less MJ04
    Sorry haven't a clue what you mean
  7. #7
    Member sulten's Avatar
    Sep 2010
    Norway
    14
    Vectra C
    Quote Originally Posted by gc1967 View Post
    MJ04=Model Jahre 2004 or MY04=Model year 2004. So if your 10th digit in WIN is 3 or less you will need to add another wire.
  8. #8
    Oct 2016
    Bedford
    97
    Quote Originally Posted by sulten View Post
    My vauxhall combo van is a 1.3 year 2008
    On opcom comes up as a Vauxhall Corsa c
  9. #9
    Aug 2016
    Frankfurt
    129
    Astra H
    Then you will good to go.....
  10. #10
    Oct 2016
    Bedford
    97
    Do you happen to know what wire to use and what connectors on each end for wire from cc stalk to bcm
  1. Fitting cruise control to zafira b Sri
    By Dala in forum Cruise Control
    Last Post: 19th October 2014, 10:27 PM
  2. fitting cruise control...
    By Ginger_Jez in forum Electrical
    Last Post: 25th September 2012, 08:37 PM
fitting cruise control to combo
vauxhall combo d cruise control
