Hi all - I have a combo van 1.3 cdti year 2008 and just want to double check I can fit cruise control on my van , I know I have a clutch switch as a error come up on my opcom the other day so I had to adjust pin on switch and then clear fault
Is there a way you can check using opcom my firmware is 1.39 - where abouts in opcom do I find it
And if I can have it I have read about fitting wire from cc stalk to BCM - what type of wire do I need to buy and what connectors need to be put on either end of the wire
Many thanks for and help given
