Hi All,
Got an issue with the horn not working at all either lights on or off. Initially I thought this was CIM related however now im less convinced.
After poking around with a multi meter there definitely is nothing reaching the horns, however there is a definite relay clicking in the UEC. After further investigation Ive narrowed it down to a relay that was under the additional cover, specifically the one with "742 355-01" poking the 2 pins on the back with a multi meter shows a definite 12V when the horn is activated however there is nothing on the output side of the relay.
Is it possible to replace just this circuit board part of the UEC or am I looking at a whole new UEC. Or are there any other possibilities as to what could cause this?
Also in terms of replacing it presumably it would need to be unpaired from the donor car then repaired with mine, I do have an unmentionable diagnostic device however I dont have the best of confidence in it tbh so would probably look for someone locally with Tech 2 if thats whats required.
