Results 1 to 2 of 2
    Astra H - Z19DTH ECU
    Pin assignment
    Pin Color Wire size Option Function
    1 Red-Blue 2.5 Z19DTL/Z19DT engines Powertrain Main Relay Fused Supply (2)
    1 Red-Blue 2.5 Engine Z19DTH Powertrain Main Relay Fused Supply (2)
    2 Brown 2.5 Z19DTL/Z19DT engines Ground
    2 Brown 2.5 Engine Z19DTH Ground
    4 Brown 2.5 Z19DTL/Z19DT engines Ground
    4 Brown 2.5 Engine Z19DTH Ground
    5 Red-Blue 2.5 Z19DTL/Z19DT engines Powertrain Main Relay Fused Supply (1)
    5 Red-Blue 2.5 Engine Z19DTH Powertrain Main Relay Fused Supply (1)
    6 Brown 2.5 Z19DTL/Z19DT engines Ground
    6 Brown 2.5 Engine Z19DTH Ground
    8 Brown-White 0.5 Z19DTL/Z19DT engines Accelerator Pedal Position Low Reference (2)
    8 Brown-White 0.5 Engine Z19DTH Accelerator Pedal Position Low Reference (2)
    9 White-Yellow 0.5 Z19DTL/Z19DT engines Accelerator Pedal Position Signal (1)
    9 White-Yellow 0.5 Engine Z19DTH Accelerator Pedal Position Signal (1)
    10 Brown-Green 0.75 Z19DTL/Z19DT engines Sensor Fuel Temperature 1 Return
    10 Brown-Green 0.75 Engine Z19DTH Sensor Fuel Temperature 1 Return
    11 Brown-White 0.75 Z19DTL/Z19DT engines Sensor Fuel Temperature 1 Signal
    11 Brown-White 0.75 Engine Z19DTH Sensor Fuel Temperature 1 Signal
    12 Brown-Black 0.5 Z19DTL/Z19DT engines A/C Refrigerant Pressure Sensor Low Reference
    12 Brown-Black 0.5 Engine Z19DTH A/C Refrigerant Pressure Sensor Low Reference
    13 Yellow-Red 0.5 Z19DTL/Z19DT engines A/C High Pressure Switch Signal
    13 Yellow-Red 0.5 Engine Z19DTH A/C High Pressure Switch Signal
    17 Brown-Gray 0.5 Z19DTL/Z19DT engines Stop Lamp Switch Signal
    17 Brown-Gray 0.5 Engine Z19DTH Stop Lamp Switch Signal
    19 Blue-White 0.5 Z19DTL/Z19DT engines Generator Turn On Signal
    19 Blue-White 0.5 Engine Z19DTH Generator Turn On Signal
    20 Brown-Red 0.5 Z19DTL/Z19DT engines Fuel Pump Primary Relay Control
    20 Brown-Red 0.5 Engine Z19DTH Fuel Pump Primary Relay Control
    22 Black-White 0.5 Z19DTL/Z19DT engines A/C Pressure Sensor 5 Volt Reference
    22 Black-White 0.5 Engine Z19DTH A/C Pressure Sensor 5 Volt Reference
    28 Black 0.75 Z19DTL/Z19DT engines Ignition Voltage
    28 Black 0.75 Engine Z19DTH Ignition Voltage
    29 Brown-Red 0.75 Z19DTL/Z19DT engines A/C Compressor Clutch Solenoid Control
    29 Brown-Red 0.75 Engine Z19DTH A/C Compressor Clutch Solenoid Control
    30 Brown-Red 0.5 Z19DTL/Z19DT engines Accelerator Pedal Position Low Reference (1)
    30 Brown-Red 0.5 Engine Z19DTH Accelerator Pedal Position Low Reference (1)
    31 White-Green 0.5 Z19DTL/Z19DT engines Accelerator Pedal Position Signal (2)
    31 White-Green 0.5 Engine Z19DTH Accelerator Pedal Position Signal (2)
    32 Blue-Green 0.5 Z19DTL/Z19DT engines Exhaust Gas Temperature Sensor (2)
    32 Blue-Green 0.5 Engine Z19DTH Exhaust Gas Temperature Sensor (2)
    33 Brown-White 0.5 Z19DTL/Z19DT engines Exhaust Gas Temperature Sensor 2 Low Reference
    33 Brown-White 0.5 Engine Z19DTH Exhaust Gas Temperature Sensor 2 Low Reference
    34 Blue-White 0.5 Z19DTL/Z19DT engines Exhaust Gas Temperature Sensor (1)
    34 Blue-White 0.5 Engine Z19DTH Exhaust Gas Temperature Sensor (1)
    35 Brown 0.5 Z19DTL/Z19DT engines Exhaust Gas Temperature Sensor 1 Low Reference
    35 Brown 0.5 Engine Z19DTH Exhaust Gas Temperature Sensor 1 Low Reference
    36 Blue 0.5 Z19DTL/Z19DT engines Exhaust Pressure Sensor Signal (1)
    36 Blue 0.5 Engine Z19DTH Exhaust Pressure Sensor Signal (1)
    37 Brown-White 0.5 Z19DTL/Z19DT engines Exhaust Pressure Sensor Low Reference (1)
    37 Brown-White 0.5 Engine Z19DTH Exhaust Pressure Sensor Low Reference (1)
    44 Gray 0.5 Z19DTL/Z19DT engines Exhaust Pressure Sensor 5 Volt Reference (1)
    44 Gray 0.5 Engine Z19DTH Exhaust Pressure Sensor 5 Volt Reference (1)
    45 Black-Red 0.5 Z19DTL/Z19DT engines Accelerator Pedal Position 5 Volt Reference (1)
    45 Black-Red 0.5 Engine Z19DTH Accelerator Pedal Position 5 Volt Reference (1)
    46 Black-Yellow 0.5 Z19DTL/Z19DT engines Accelerator Pedal Position 5 Volt Reference (2)
    46 Black-Yellow 0.5 Engine Z19DTH Accelerator Pedal Position 5 Volt Reference (2)
    51 Brown-Green 0.75 Z19DTL/Z19DT engines Heated Oxygen Sensor Heater High Control Bank 1 Sensor (3)
    51 Brown-Green 0.75 Engine Z19DTH Heated Oxygen Sensor Heater High Control Bank 1 Sensor (3)
    52 Blue 0.5 Z19DTL/Z19DT engines Glow Plug Controller Diagnostic Signal
    52 Blue 0.5 Engine Z19DTH Glow Plug Controller Diagnostic Signal
    64 Yellow-Red 0.5 Z19DTL/Z19DT engines Heated Oxygen Sensor Collector Signal
    64 Yellow-Red 0.5 Engine Z19DTH Heated Oxygen Sensor Collector Signal
    65 Brown-White 0.5 Z19DTL/Z19DT engines Heated Oxygen Sensor Current Pump Signal
    65 Brown-White 0.5 Engine Z19DTH Heated Oxygen Sensor Current Pump Signal
    68 Blue-Green 0.5 Z19DTL/Z19DT engines Heater Fuel Control
    68 Blue-Green 0.5 Engine Z19DTH Heater Fuel Control
    69 Brown-Yellow 0.75 Z19DTL/Z19DT engines Cooling Fan Relay Coil Control
    69 Brown-Yellow 0.75 Engine Z19DTH Cooling Fan Relay Coil Control
    70 Black-Red 0.75 Z19DTL/Z19DT engines Starter Relay Coil Control
    70 Black-Red 0.75 Engine Z19DTH Starter Relay Coil Control
    72 Brown-White 0.5 Z19DTL/Z19DT engines Engine Main Relay Coil Control
    72 Brown-White 0.5 Engine Z19DTH Engine Main Relay Coil Control
    74 Blue-Yellow 0.5 Z19DTL/Z19DT engines Water In Fuel Sensor Signal
    74 Blue-Yellow 0.5 Engine Z19DTH Water In Fuel Sensor Signal
    75 Blue-Red 0.5 Z19DTL/Z19DT engines Generator Field Duty Cycle Signal
    75 Blue-Red 0.5 Engine Z19DTH Generator Field Duty Cycle Signal
    79 Gray 0.5 Z19DTL/Z19DT engines Cruise Control Clutch Pedal Position Switch Signal
    79 Gray 0.5 Engine Z19DTH Cruise Control Clutch Pedal Position Switch Signal
    80 Black-Brown 0.5 Z19DTL/Z19DT engines ABS Brake Switch Signal
    80 Black-Brown 0.5 Engine Z19DTH ABS Brake Switch Signal
    83 Green 0.5 Z19DTL/Z19DT engines High Speed GMLAN Serial Data (-) (1)
    83 Green 0.5 Engine Z19DTH High Speed GMLAN Serial Data (-) (1)
    84 Blue 0.5 Z19DTL/Z19DT engines High Speed GMLAN Serial Data (+) (1)
    84 Blue 0.5 Engine Z19DTH High Speed GMLAN Serial Data (+) (1)
    86 Brown 0.5 Z19DTL/Z19DT engines Heated Oxygen Sensor Common
    86 Brown 0.5 Engine Z19DTH Heated Oxygen Sensor Common
    87 Green 0.5 Z19DTL/Z19DT engines Heated Oxygen Sensor Current Adjust Signal
    87 Green 0.5 Engine Z19DTH Heated Oxygen Sensor Current Adjust Signal
    90 Brown-Red 0.75 Z19DTL/Z19DT engines Cooling Fan Relay Coil Control
    90 Brown-Red 0.75 Engine Z19DTH Cooling Fan Relay Coil Control
    93 Brown-Gray 0.5 Z19DTL/Z19DT engines Glow Plug Control
    93 Brown-Gray 0.5 Engine Z19DTH Glow Plug Control
    94 White-Black 0.75 Z19DTL/Z19DT engines Cooling Fan Relay Coil Control
    94 White-Black 0.75 Engine Z19DTH Cooling Fan Relay Coil Control
Name:	EDC16c39 - 1.jpg
Name:	EDC16c39 - 2.jpg
      Pin assignment
      1 Brown-White 1.5 Fuel Injector Control (3)
      2 Gray-Red 1.5 Fuel Injector Control (2)
      6 Yellow-Blue 0.5 -
      8 Black-Violet 0.5 Fuel Rail Pressure Sensor (5) Volt Reference
      11 White 0.5 Camshaft Position Sensor Low Reference
      12 White-Yellow 0.5 Crankshaft Sensor Low Reference (1)
      13 White-Orange 0.5 Turbo Boost Pressure Sensor 5 Volt Reference
      15 Green-Black 0.75 Waste Gate Solenoid Control
      16 Blue-Red 1.5 Fuel Injector Control (1)
      17 Red-Yellow 1.5 Fuel Injector Control (4)
      19 Yellow-Black 0.75 Electronic Control Unit 12 Volt Reference (1)
      20 Violet-Yellow 0.5 Camshaft Position Sensor 5V Control
      21 Brown-Green 0.75 Oil Level Switch Signal
      23 Brown-Violet 0.5 Turbo Boost Pressure Sensor Low Reference
      27 Gray-Black 0.5 Crankshaft Sensor Signal (1)
      28 Red-Green 0.5 Fuel Rail Pressure Sensor Low Reference
      31 Gray-Black 1.5 Fuel Pump Control
      33 Red-Black 1.5 Fuel Pump Control
      35 Violet-White 0.5 -
      37 White-Blue 0.5 Mass Air Flow Sensor Low Reference
      39 White-Black 0.5 Throttle Position Sensor Low Reference
      40 White-Red 0.5 Turbo Boost Pressure Sensor Signal
      41 Gray-Green 0.5 Engine Coolant Temperature Sensor Signal
      42 Light Blue-Green 0.5 Mass Air Flow Sensor Signal
      43 Yellow 0.5 Fuel Rail Pressure Sensor Signal
      44 Yellow-Gray 0.5 Intake Air Temperature Sensor Signal
      45 Green-Gray 0.75 -
      46 Brown-Black 1.5 Fuel Pump Control
      47 Blue-Black 1.5 Fuel Pump Control
      49 Orange-Black 0.75 High Pressure Fuel Pump Actuator Low - Control
      50 Gray-White 0.5 Camshaft Position Sensor Signal
      52 Orange 0.5 Throttle Position Sensor Signal (1)
      53 White-Green 0.5 Turbo Boost Pressure Sensor Temperature Signal
      56 Gray-Blue 0.5 Oil Pressure Switch Signal
      58 Blue-Red 0.5 Signal Ground
      59 Yellow-Red 0.75 Electronic Throttle Control Actuator Signal
      60 Orange-Green 0.75 Exhaust Gas Recirculation Vent Solenoid Control
  1. ecu power pins on a vauxhall astra 1.4 mk petrol 2006
    By stevenmralph in forum Introductions
    Last Post: 25th October 2019, 08:36 AM
  2. Replies: 2
    Last Post: 12th June 2019, 10:31 AM
  3. vectra c airbag ecu b1000 ecu fault how fix
    By lampinen in forum Vectra
    Last Post: 2nd November 2018, 06:12 PM
  4. New blank 1.3 ECU
    By Miriada 4344 in forum Corsa
    Last Post: 26th October 2018, 05:14 AM
https:www.diagnostics.org.ukshowthread.php619-Astra-H-Z19DTH-ECU
astra z19dth wiring diagram
z19dth ecu pinout
https:diagnostics.org.ukshowthread.php619-Astra-H-Z19DTH-ECU
wiring diagram for astra h glow plugs
astra z19dth relay diagramz19dt colling ecuastra wiring diagram of the glow plug circuitastra diagram of the glow plug circuitvauxhall z19dth engine diagramwiring diagram Z19DTHz19dth egr wiring testpinout color size of opel astra ecm wiresz19dth o2 sensorvauxhall engine diagram z19dthastra h wiring diagramz19dth ecuz19dt ecu pinoutastra h 1.4 16v ecu pinoutdiagram ecu astra h 1.6Astra Z19DTH glow plugs diagnosticszafira vauxhall 1.9cdti 2008 ecu wiringz19dt cam sensor wiring diagramz19dth coolant temperature sensor
