Ι write what i can read from chip.
ATHEL 606
250040 AN
6027
ATHEL 606
250040 AN
6027
yes that is correct chip, now you need to get eprom reader and remove chip and read the file, or use clip and read the file. once we have the bin file then we can decode it.
if you dont know what eprom reader is have a google for it and understand.
.if i resolder the eeprom chip and solder from my old rec chip with my codes may i solved my problem?
if the rec same part number then yes.
Same id number but the second it was from zafira
good morning i bought her a cd30 mp3 OPEL CORSA D
DELPHI GRUNDIG
GM03361865778
13257028
344183129
26.06.2006 and I want to mount it in a ASTRA H we use unlock codes so you can be helped
post up the eprom file for unlock code
good morning the eprom file is 24C32 smd thanks
Regards
Semzak
You need to read eprom with eprom reader to get the .bin file from it... like using upa-usb or similar
