Results 1 to 4 of 4
Hybrid View
    Member LeeMutz's Avatar
    Mar 2014
    Gloucester
    25
    Astra H VXR
    H VXR ECU issues need coding somehow
    55 plate VXR, running like a pig! Had a remapper pull the ECU ID today and it's coming up as a Z20LEL instead of LEH and also a different VIN. So either the wrong ECU has been coded to the car, or, someone has loaded a LEL map from a different car into the ECU (sounds more probable).
    What at are my options? Can you reset my current ECU so it can be coded? Clearly I have wrong software...
    mapper cant progress as they will pull the software and modify that, and they'd be modifying the wrong software parameters.
    Any help would be muchly appreciated.
    This is the ECU I have on the car. Which seems rare as hell as I can't find another on eBay
  2. #2
    Member liviu2004's Avatar
    Feb 2014
    Netherlands
    150
    Opel
    Flash the ecu with tech2/sps or mdi/sps.
  3. #3
    Member Chris Sams's Avatar
    Feb 2015
    East Midlands
    7
    Nov 2007 Astra H
  4. #4
    Can be pain flashing it with tech2 if tech will detect it ad lel ecu than you will need to swap tech files to leh otherwise it will flash it again with lel or worst case throw an error
    2nd option is on bench
  1. Replies: 2
    Last Post: 12th June 2019, 10:31 AM
  2. vectra c airbag ecu b1000 ecu fault how fix
    By lampinen in forum Vectra
    Last Post: 2nd November 2018, 06:12 PM
  3. New blank 1.3 ECU
    By Miriada 4344 in forum Corsa
    Last Post: 26th October 2018, 05:14 AM
