Hi pecky!
I've got a CDC40 opera 24c32 eprom to decoding..
It's possible to send a divorced file?
Thank you very much
Dump moved to Archive
Hi pecky!
Thank you very much
I don't reset files, its much safer to use tech2 or opcom to reset it.
REPORT GENERATED BY PECKY'S VAUXHALL DECODER
File Name: 24c32 CDC40.bin
Unit: Delphi Grundig CDC40
EEPROM: 24c32 EEPROM
Vehicle:
Security Code: 3628
Model:CDC 40 OPERA
Serial Number:GM0D40C1001075
Part Number:13189438
Hardware Number:13251356
Production Date:02.04.2012
Ident:AN
Software Date:19.02.2007
Code Index:012
Audio Index:024
Temperature Index:029
Remaining Attempts:10
Wait Time:Not Running
Pecky, after I divorced my cd30mp3, I install de cdc40, I desactivate the Theft Protection with the code that you gave me (3628) successfully with the radio safe and display safe info in my GID. When I tried to activate once again with my cars factory code It gaves me two errors
My radio status is:
My GID status is:
Should I try to reload the original bin file into the eprom?
Timeout means its trying to find an item on the canbus network which either isnt responding or isnt there.
Check the midspeed can setup on both the radio and display and also the uhp4 (bluetooth) if present, and also ECC (dual zone climate control) if present, plus DAB as well.
In your case as your changing the headunit only, check the midspeed can on your old cd30 and the midspeed on the cdc40 your fitting.. (also make sure DAB is not present unless you have fitted the seperate dab unit by the footwell as well)
Based in soulman post (the unit is trying to find some module not present)
Just to 'close' this thread, I re-write the cdc40 eprom the the 1st file that I read (present in the 1st post) and then I tried to divorce it with opcom with one diference. 1st of all I deactivated the DAB module that the new radio had 'on' and my car don't have it, then I divorced and then married it successfully!
Hello.
I need a pin from dump of my cdc40 opera delphi grundig.
thank you very much!.
cannot decode this one for some reason. will open it up and have a look later if i get a chance
code is 9633...
File Name: CDC40 OPERA.bin
Vehicle: Vectra C
Security Code:9633
Model:CDC 40 OPERA
Serial Number:GM0D4070228998
Part Number:13189439
Hardware Number:13204012
Production Date:22.08.2007
Ident:XR
Code Index:021
Audio Index:043
Temperature Index:ÿÿÿ
Remaining Attempts:7
Wait Time:Running
