IL Part No. KAT No. Description Range Range QTY
BATTERY - EXCEPT VAUXHALL
1 (19001888) (12 01 283) BATTERY, 12V.36 AMP (NLS.- USE 19001889) 1
2 19001889 12 01 284 BATTERY, 12V.44 AMP 1
3 (93179245) (12 01 205) BATTERY, 12V.55 AMP (NLS.- USE 19003129) 1
4 (9201872) (62 01 252) BATTERY, 12V.60 AMP (IDENT ET) (NLS.- USE 9201873) 1
4 (19023518) (62 01 279) BATTERY, 12V.60 AMP (NLS.- USE 19001894) 1
4 19001894 12 01 289 BATTERY, 12V.64 AMP 1
5 (93179266) (62 01 253) BATTERY, 12V.66 AMP (NLS.- USE 19003130) 1
6 9201470 62 01 271 BATTERY, 12V.70 AMP 1
7 19023517 62 01 278 BATTERY, 12V.72 AMP 1
BATTERY - FOR VAUXHALL
8 (19001888) (12 01 283) BATTERY, 12V.36 AMP (NLS.- USE 19001889) 1
9 (19001177) BATTERY, 12V.44 AMP (NLS.- USE 19001889) 1
10 (19002983) BATTERY, 12V.55 AMP (NLS.- USE 19003129) 1
11 (91158375) BATTERY, 12V.60 AMP (IDENT ET) (NLS.- USE 9201873) 1
12 (93003276) BATTERY, 12V.66 AMP (NLS.- USE 19003130) 1
13 (91158372) BATTERY, 12V.70 AMP (NLS.- USE 9201470) 1
14 (9159075) (67 77 173) BATTERY, 12V.72 AMP (NLS.- NO REPLACEMENT PART) 1
BATTERY FIXINGS
15 13157732 12 00 387 CAP, PROTECTIVE, POSITIVE POLE 1
16 90228223 2 60 219 BRACKET, BATTERY RETAINING 1
17 11092154 20 02 134 SCREW, HEX.HD., M8 X 25, BATTERY RETAINING BRACKET FIXING 1
18 13165712 2 60 250 TRAY, ASSY., BATTERY (FOR USE WITH 0-55AMP BATTERY) 1
19 (13110827) (2 60 249) TRAY, ASSY., BATTERY (FOR USE WITH 60-72AMP BATTERY) (NLS.- USE 13234223) (C)
(C)
(C)
-52999999
-55999999
-58999999
1
19 13234223 2 60 041 TRAY, ASSY., BATTERY (FOR USE WITH 60-72AMP BATTERY) Z12XEP, Z14XEL, Z14XEP, Z16XEP, Z16XE1, Z16XER, A16XER, Z16LET, A16LET, Z18XE, Z18XER, A18XER, Z20LEL, Z20LER, Z20LEH, Z22YH, Z13DTH, Z17DTL, Z17DTH, Z17DTJ, A17DTJ, Z19DTL, Z19DT, Z19DTH (C) 62000001-
(C) 65000001-
(C) 68000001-
(C) 8B000001-
1
19 13235804 2 60 044 TRAY, ASSY., BATTERY Z17DTJ, A17DTJ, Z17DTR, A17DTR 1
20 11058096 20 02 629 SCREW, BATTERY TRAY, M8 X 18 3
21 90588752 12 01 770 COVER, BATTERY PROTECTION (FOR USE WITH 60AMP BATTERY) Z19DTL, Z19DT, Z19DTJ, Z19DTH 1
21 90588752 12 01 770 COVER, BATTERY PROTECTION (FOR USE WITH 66AMP BATTERY) (FOR HOT CLIMATE PACKAGE) (C)
(C)
(C)
-52999999
-55999999
-58999999
1
21 90588752 12 01 770 COVER, BATTERY PROTECTION (FOR USE WITH 66AMP BATTERY) (FOR BATTERY ISOLATOR) (C) 62000001-
(C) 65000001-
(C) 68000001-
(C) 8B000001-
1
22 90588753 12 01 771 COVER, BATTERY PROTECTION (FOR USE WITH 70AMP BATTERY) (C)
(C)
-45999999
-48999999
1
22 90588753 12 01 771 COVER, BATTERY PROTECTION (FOR USE WITH 70AMP BATTERY) (FOR HOT CLIMATE PACKAGE) (C) 52000001-
(C) 55000001-
(C) 58000001-
52999999
55999999
58999999
1
22 90588753 12 01 771 COVER, BATTERY PROTECTION (FOR USE WITH 70AMP BATTERY) (EXC.HOT CLIMATE PACKAGE) Z19DTL, Z19DT, Z19DTH (C) 52000001-
(C) 55000001-
(C) 58000001-
(C) 8B000001-
1
22 90588753 12 01 771 COVER, BATTERY PROTECTION (FOR USE WITH 70AMP BATTERY) (FOR BATTERY ISOLATOR) (C) 62000001-
(C) 65000001-
(C) 68000001-
(C) 8B000001-
1
22 90588753 12 01 771 COVER, BATTERY PROTECTION (FOR USE WITH 72 AMP BATTERY) (FOR BATTERY ISOLATOR) 1
- 93165363 12 01 855 RETAINER, SOCKET, VENTILATOR, BATTERY 1
