Results 1 to 10 of 22
Hybrid View
    Engine and Cooling
    IL Part No. KAT No. Description Range Range QTY
    BATTERY - EXCEPT VAUXHALL
    1 (19001888) (12 01 283) BATTERY, 12V.36 AMP (NLS.- USE 19001889) 1
    2 19001889 12 01 284 BATTERY, 12V.44 AMP 1
    3 (93179245) (12 01 205) BATTERY, 12V.55 AMP (NLS.- USE 19003129) 1
    4 (9201872) (62 01 252) BATTERY, 12V.60 AMP (IDENT ET) (NLS.- USE 9201873) 1
    4 (19023518) (62 01 279) BATTERY, 12V.60 AMP (NLS.- USE 19001894) 1
    4 19001894 12 01 289 BATTERY, 12V.64 AMP 1
    5 (93179266) (62 01 253) BATTERY, 12V.66 AMP (NLS.- USE 19003130) 1
    6 9201470 62 01 271 BATTERY, 12V.70 AMP 1
    7 19023517 62 01 278 BATTERY, 12V.72 AMP 1
    BATTERY - FOR VAUXHALL
    8 (19001888) (12 01 283) BATTERY, 12V.36 AMP (NLS.- USE 19001889) 1
    9 (19001177) BATTERY, 12V.44 AMP (NLS.- USE 19001889) 1
    10 (19002983) BATTERY, 12V.55 AMP (NLS.- USE 19003129) 1
    11 (91158375) BATTERY, 12V.60 AMP (IDENT ET) (NLS.- USE 9201873) 1
    12 (93003276) BATTERY, 12V.66 AMP (NLS.- USE 19003130) 1
    13 (91158372) BATTERY, 12V.70 AMP (NLS.- USE 9201470) 1
    14 (9159075) (67 77 173) BATTERY, 12V.72 AMP (NLS.- NO REPLACEMENT PART) 1
    BATTERY FIXINGS
    15 13157732 12 00 387 CAP, PROTECTIVE, POSITIVE POLE 1
    16 90228223 2 60 219 BRACKET, BATTERY RETAINING 1
    17 11092154 20 02 134 SCREW, HEX.HD., M8 X 25, BATTERY RETAINING BRACKET FIXING 1
    18 13165712 2 60 250 TRAY, ASSY., BATTERY (FOR USE WITH 0-55AMP BATTERY) 1
    19 (13110827) (2 60 249) TRAY, ASSY., BATTERY (FOR USE WITH 60-72AMP BATTERY) (NLS.- USE 13234223) (C)
    (C)
    (C)
    -52999999
    -55999999
    -58999999
    1
    19 13234223 2 60 041 TRAY, ASSY., BATTERY (FOR USE WITH 60-72AMP BATTERY) Z12XEP, Z14XEL, Z14XEP, Z16XEP, Z16XE1, Z16XER, A16XER, Z16LET, A16LET, Z18XE, Z18XER, A18XER, Z20LEL, Z20LER, Z20LEH, Z22YH, Z13DTH, Z17DTL, Z17DTH, Z17DTJ, A17DTJ, Z19DTL, Z19DT, Z19DTH (C) 62000001-
    (C) 65000001-
    (C) 68000001-
    (C) 8B000001-
    1
    19 13235804 2 60 044 TRAY, ASSY., BATTERY Z17DTJ, A17DTJ, Z17DTR, A17DTR 1
    20 11058096 20 02 629 SCREW, BATTERY TRAY, M8 X 18 3
    21 90588752 12 01 770 COVER, BATTERY PROTECTION (FOR USE WITH 60AMP BATTERY) Z19DTL, Z19DT, Z19DTJ, Z19DTH 1
    21 90588752 12 01 770 COVER, BATTERY PROTECTION (FOR USE WITH 66AMP BATTERY) (FOR HOT CLIMATE PACKAGE) (C)
    (C)
    (C)
    -52999999
    -55999999
    -58999999
    1
    21 90588752 12 01 770 COVER, BATTERY PROTECTION (FOR USE WITH 66AMP BATTERY) (FOR BATTERY ISOLATOR) (C) 62000001-
    (C) 65000001-
    (C) 68000001-
    (C) 8B000001-
    1
    22 90588753 12 01 771 COVER, BATTERY PROTECTION (FOR USE WITH 70AMP BATTERY) (C)
    (C)
    -45999999
    -48999999
    1
    22 90588753 12 01 771 COVER, BATTERY PROTECTION (FOR USE WITH 70AMP BATTERY) (FOR HOT CLIMATE PACKAGE) (C) 52000001-
    (C) 55000001-
    (C) 58000001-
    52999999
    55999999
    58999999
    1
    22 90588753 12 01 771 COVER, BATTERY PROTECTION (FOR USE WITH 70AMP BATTERY) (EXC.HOT CLIMATE PACKAGE) Z19DTL, Z19DT, Z19DTH (C) 52000001-
    (C) 55000001-
    (C) 58000001-
    (C) 8B000001-
    1
    22 90588753 12 01 771 COVER, BATTERY PROTECTION (FOR USE WITH 70AMP BATTERY) (FOR BATTERY ISOLATOR) (C) 62000001-
    (C) 65000001-
    (C) 68000001-
    (C) 8B000001-
    1
    22 90588753 12 01 771 COVER, BATTERY PROTECTION (FOR USE WITH 72 AMP BATTERY) (FOR BATTERY ISOLATOR) 1
    - 93165363 12 01 855 RETAINER, SOCKET, VENTILATOR, BATTERY 1
  2. #2
    SPARK PLUG - PETROL ENGINES
    1 93176801 12 14 031 PLUG, ASSY., SPARK (PACK OF 10) (FQR8LE2) Z12XEP, Z14XEL, Z14XEP, Z16XEP, Z16XE1, Z16XER, A16XER, Z18XE, Z18XER, A18XER 4
    1 55565219 12 14 016 PLUG, ASSY., SPARK (EXCEPT DUAL FUEL - LPG) Z16XER, A16XER 4
    1 55564763 12 14 528 PLUG, ASSY., SPARK (ZFR6BP-G) Z16LET, A16LET 4
    1 93180485 12 14 041 PLUG, ASSY., SPARK (FQR8LE2) (PACK OF 10) Z20LEL, Z20LER 4
    1 55562534 12 14 046 PLUG, ASSY., SPARK Z20LEH 4
    1 93175880 12 14 027 PLUG, ASSY., SPARK (14FGR8DOU7) (PACK OF 10) Z22YH 4
    GLOW PLUG - DIESEL ENGINES
    2 93178047 12 14 032 PLUG, ASSY., GLOW, HEATER Z13DTH 4
    3 97358626 12 14 035 PLUG, ASSY., GLOW, HEATER Z17DTL 4
    3 97358626 12 14 035 PLUG, ASSY., GLOW, HEATER Z17DTH (E) -1705894 4
    3 97389905 12 14 063 PLUG, ASSY., GLOW, HEATER Z17DTH (E) 1705895- 4
    4 93180295 12 14 040 PLUG, ASSY., GLOW, HEATER Z19DTL, Z19DT (C)
    (C)
    (C)
    -72045139
    -75030986
    -78007391
    4
    5 93190433 12 14 064 PLUG, ASSY., GLOW, HEATER Z19DTL, Z19DT (C) 72045140-
    (C) 75030987-
    (C) 78007392-
    (C) 8B000001-
    4
    6 93178411 12 14 034 PLUG, ASSY., GLOW, HEATER Z19DTJ, Z19DTH 4
    7 97389905 12 14 063 PLUG, ASSY., GLOW, HEATER Z17DTJ, A17DTJ, Z17DTR, A17DTR 4
    GLOW PLUG RELAY AND CONTROL UNIT - DIESEL ENGINES
    8 55353011 62 35 240 UNIT, CONTROL, GLOW TIME (BLUE) Z13DTH, Z19DTL, Z19DT, Z19DTJ, Z19DTH 1
    8 55354141 62 35 303 UNIT, CONTROL, GLOW TIME (BLACK) Z17DTL, Z17DTH, Z17DTJ, Z17DTJ, A17DTJ, Z17DTR, A17DTR, Z19DTL, Z19DT, Z19DTH 1
    - 90542114 15 03 170 COMPOUND, SEALING, GLOW PLUG CONTROL UNIT 1
  3. #3
    STARTER - Z12XEP,Z14XEL,Z14XEP PETROL ENGINES (NEW)
    1 9115192 62 02 075 STARTER, ASSY. (VALEO) (EXCHANGE PART 93189230 OPEL) Z12XEP, Z14XEP 1
    2X 90421774 12 03 047 -KIT, REPAIR, STARTER 1
    3 90543809 12 03 995 -TRANSMISSION, PLANETARY, WITH MOTOR 1
    4 90543810 62 03 150 -PINION, STARTER 1
    5X 9192954 16 12 012 -KIT, REPAIR, ENGAGING FORK 1
    6 8956812 6 62 512 SCREW, HEX.HD., M8 X 48, STARTER TO CYLINDER BLOCK 1
    7 11048336 20 18 000 SCREW, HEX.HD., M8 X 25, STARTER TO CYLINDER BLOCK 1
    - 55561930 20 00 541 SCREW, HEX.HD., M8 X 48, STARTER TO CYLINDER BLOCK Z14XEP 1
    - 55566800 12 02 110 STARTER, ASSY. (BOSCH) Z14XEP 1
    STARTER - Z12XEP,Z14XEL,Z14XEP PETROL ENGINES (EXCHANGE)
    1 93189230 62 02 094 STARTER, ASSY., EXCHANGE (CORE RETURN NO. 95 62 167) (EXCEPT VAUXHALL) 1
    1 R1540024 STARTER, ASSY., EXCHANGE (FOR VAUXHALL) (CORE RETURN NO. C1540024) 1
  4. #4
    STARTER (CONTD.) - Z16XEP,Z16XE1 PETROL ENGINES (NEW)
    1 (93175996) (62 02 061) STARTER, ASSY. (NLS.- USE 93184535) (EXCHANGE PART 93189230 OPEL, R1540024 VAUXHALL) (C)
    (C)
    (C)
    -62097898
    -65096746
    -68071397
    1
    1 (93184535) (62 02 079) STARTER, ASSY. (NLS.- USE 9115192) (EXCHANGE PART 93189230 OPEL) (C)
    (C)
    (C)
    -62097898
    -65096746
    -68071397
    1
    1 9115192 62 02 075 STARTER, ASSY. (IDENT D6RA93) (EXCHANGE PART 93189230 OPEL) (C)
    (C)
    (C)
    -62097898
    -65096746
    -68071397
    1
    2 93176042 62 02 063 -SWITCH, STARTER 1
    3X (9199524) (12 03 025) -SET, CARBON BRUSHES, WITH HOLDER (NLS.- USE 93178218) 1
    4 93170382 62 03 987 -TRANSMISSION, PLANETARY, WITH MOTOR 1
    5X 9199525 16 12 037 -KIT, REPAIR, STARTER 1
    6 93176041 62 02 062 -PINION, STARTER 1
    7 90543809 12 03 995 -TRANSMISSION, PLANETARY, WITH MOTOR 1
    8 90543810 62 03 150 -PINION, STARTER (C)
    (C)
    (C)
    -62097898
    -65096746
    -68071397
    1
    9X 9192954 16 12 012 -KIT, REPAIR, ENGAGING FORK 1
    10X 90421774 12 03 047 -KIT, REPAIR, STARTER 1
    11 8956812 6 62 512 SCREW, HEX.HD., M8 X 48, STARTER TO CYLINDER BLOCK 1
    12 11048336 20 18 000 SCREW, HEX.HD., M8 X 25, STARTER TO CYLINDER BLOCK 1
    1 55556092 62 02 084 STARTER, ASSY. (EXCHANGE PART 93169022 OPEL) (C) 62097899-
    (C) 65096747-
    (C) 68071398-
    (C) 8B000001-
    1
    2 93192288 12 02 254 -SOLENOID SWITCH, STARTER 1
    3X 93192289 12 03 682 -SET, CARBON BRUSHES, WITH HOLDER 1
    4 93192287 12 03 681 -TRANSMISSION, PLANETARY, STARTER 1
    6 93192286 12 03 680 -PINION, STARTER 1
    STARTER (CONTD.) - Z16XEP PETROL ENGINES (EXCHANGE)
    1 93189230 62 02 094 STARTER, ASSY., EXCHANGE (CORE RETURN NO. 95 62 167) (EXCEPT VAUXHALL) (C)
    (C)
    (C)
    -62097898
    -65096746
    -68071397
    1
    1 R1540024 STARTER, ASSY., EXCHANGE (FOR VAUXHALL) (CORE RETURN NO. C1540024) (C)
    (C)
    (C)
    -62097898
    -65096746
    -68071397
    1
    STARTER (CONTD.) - Z16XER,A16XER,Z16LET,A16LET PETROL ENGINES (NEW)
    1 55556092 62 02 084 STARTER, ASSY. (EXCHANGE PART 93169022 OPEL) 1
    13 55561930 20 00 541 SCREW, STARTER TO CYLINDER BLOCK, M8 X 48 Z16XER 1
  5. #5
    STARTER (CONTD.) - Z18XE PETROL ENGINE
    1 93176051 62 02 064 STARTER, ASSY. (EXCHANGE PART 93175885 OPEL) 1
    2X 93178218 62 03 010 -SET, CARBON BRUSHES, WITH HOLDER 1
    3 9199520 62 03 986 -TRANSMISSION, PLANETARY, WITH MOTOR 1
    4 90141625 12 03 238 -BUSH, DRIVE PINION 2
    5 93176042 62 02 063 -SWITCH, STARTER 1
    6 9199523 12 03 206 -BUSH, DRIVE END 1
    7 93176041 62 02 062 -PINION, STARTER 1
    8X 9199525 16 12 037 -KIT, REPAIR, STARTER 1
    9 8956812 6 62 512 SCREW, HEX.HD., M8 X 48, STARTER TO CYLINDER BLOCK 1
    10 11048336 20 18 000 SCREW, HEX.HD., M8 X 25, STARTER TO CYLINDER BLOCK 1
  6. #6
    STARTER (CONTD.) - Z18XER,A18XER PETROL ENGINES (NEW)
    5 93192286 12 03 680 -PINION, STARTER 1
    6 55561930 20 00 541 SCREW, STARTER TO CYLINDER BLOCK, M8 X 48 (USED WITH AUTOMATIC TRANSMISSION) 1
  1. Insignia engine ECM
    By soulman in forum Insignia
    Last Post: 25th March 2016, 07:25 PM
  2. 1 - Engine and Cooling
    By pecky in forum P - ELECTRICAL
    Last Post: 28th December 2013, 08:48 PM
  3. Cooling fan problem
    By Rob in forum Zafira
    Last Post: 18th July 2013, 06:21 PM
  4. Engine code
    By mull3tt mk5 in forum Astra
    Last Post: 6th December 2012, 10:00 AM
  5. Engine Diagram: What is it?
    By samnjl in forum Astra
    Last Post: 21st November 2012, 09:00 AM
62 01 271 er
gm 62 01 271 er
gm 62 01 252
denso pressure regulator z17dth
z16xep engine diagram
astra h opc 96418393
Z18xe Vectra engine diagram
93169030
62 01 252 et
A16Let engine diagram
z13dth water temp
gm 13126354
car battery 62 01 271 er
97364345z18xe diagramwhat is 93179112 vectabattery 62 01 252 etz18xer diagramz13dth timing beltsz16xep starter motor locationZ16XE1 TEMPERATUREZ17dth crankshaft sensor aopel 62 01 27162 01 25297364342 vauxhall
