IL |
Part No. |
KAT No. |
Description |
Range |
Range |
QTY |
ALTERNATOR - Z12XEP,Z14XEL,Z14XEP PETROL ENGINES BOSCH (NEW) |
1 |
93180416 |
62 04 193 |
ALTERNATOR, ASSY., 12V.70 AMP (IDENT ZC) (EXCHANGE PART 93189247 OPEL, R1530083 VAUXHALL) |
(C)
(C)
(C) |
-52999999
-55999999
-58999999 |
1 |
2 |
93183435 |
62 04 203 |
ALTERNATOR, ASSY., 12V.100 AMP (IDENT ZL) (EXCHANGE PART 93189242 OPEL, R1530078 VAUXHALL) |
1 |
2 |
93190139 |
62 04 266 |
ALTERNATOR, ASSY., 12V.120 AMP (IDENT ZZ) |
1 |
3 |
93175990 |
12 04 391 |
-PULLEY, ALTERNATOR |
1 |
4 |
93175991 |
62 04 886 |
-NUT, HEX., M16, PULLEY TO ALTERNATOR |
1 |
5 |
9117938 |
12 06 357 |
-BEARING, ALTERNATOR, FRONT |
1 |
6 |
9117939 |
12 06 392 |
-RING, ALTERNATOR BEARING, REAR |
1 |
7 |
93174476 |
12 04 246 |
-REGULATOR, ASSY., ALTERNATOR |
1 |
8 |
93182481 |
12 05 473 |
-DIODE PLATE, ALTERNATOR (FOR USE WITH 70 AMP. ALTERNATOR) |
1 |
8 |
93172292 |
12 05 558 |
-DIODE PLATE, ALTERNATOR (FOR USE WITH 100/120 AMP. ALTERNATOR) |
1 |
9 |
9117940 |
12 06 358 |
-BEARING, ALTERNATOR, REAR |
1 |
10 |
9118144 |
12 05 964 |
-CAP, PROTECTING, ALTERNATOR, REAR (FOR USE WITH 100/120 AMP. ALTERNATOR) |
1 |
11 |
93172450 |
62 04 870 |
-NUT, PROTECTIVE COVER FIXING (FOR USE WITH 70 AMP. ALTERNATOR) |
1 |
12 |
93175984 |
12 05 602 |
-NUT, PROTECTIVE COVER FIXING |
1 |
13 |
93190138 |
62 04 265 |
ALTERNATOR, ASSY., 100 AMP (IDENT ZY) |
1 |
93190140 |
12 05 476 |
-DIODE PLATE, ALTERNATOR (FOR USE WITH 100 AMP. ALTERNATOR) |
1 |
93190141 |
62 04 267 |
1 |
22 |
93175990 |
12 04 391 |
1 |
9117938 |
12 06 357 |
1 |
9117939 |
12 06 392 |
1 |
23 |
93175991 |
62 04 886 |
1 |
2 |
93180417 |
62 04 194 |
ALTERNATOR, ASSY., 12V.120 AMP (IDENT ZD) (EXCHANGE PART 93189245 OPEL, R1530081 VAUXHALL) |
1 |
ALTERNATOR - Z12XEP,Z14XEL,Z14XEP PETROL ENGINES DENSO (NEW) |
14 |
(93187819) |
(62 04 244) |
ALTERNATOR, ASSY., 12V.70 AMP (IDENT ZT) (NLS.- USE 13283344) |
(C) 62000001-
(C) 65000001-
(C) 68000001-
(C) 8B000001- |
1 |
24 |
13222929 |
62 04 256 |
ALTERNATOR, ASSY., 70 AMP (IDENT ZX) |
1 |
ALTERNATOR - Z12XEP,Z14XEL,Z14XEP PETROL ENGINES VALEO (NEW) |
14 |
13283344 |
62 04 291 |
ALTERNATOR, ASSY. (12V.100 AMP) (VALEO) (IDENT BW) |
(C) 62000001-
(C) 65000001-
(C) 68000001-
(C) 8B000001-
(C) |
92
95
98
9B
-9G |
1 |
ALTERNATOR - Z12XEP,Z14XEL,Z14XEP PETROL ENGINES EXCHANGE |
2 |
93189242 |
62 04 239 |
ALTERNATOR, ASSY., 12V.100 AMP, EXCHANGE (IDENT ZL) (CORE RETURN NO. 95 62 176) (EXCEPT VAUXHALL) (SERVICES PRODUCTION NO. 93183435) |
1 |
2 |
93189245 |
62 04 242 |
ALTERNATOR, ASSY., 12V.120 AMP, EXCHANGE (IDENT ZD) (CORE RETURN NO. 95 62 177) (EXCEPT VAUXHALL) (SERVICES PRODUCTION NO. 93180417) |
1 |
2 |
R1530078 |
ALTERNATOR, ASSY., 12V.100 AMP, EXCHANGE (IDENT ZL) (FOR VAUXHALL) (CORE RETURN NO. C1530078) (SERVICES PRODUCTION NO. 93183435) |
1 |
2 |
R1530081 |
ALTERNATOR, ASSY., 12V.120 AMP, EXCHANGE (IDENT ZD) (FOR VAUXHALL) (CORE RETURN NO. C1530081) (SERVICES PRODUCTION NO. 93180417) |
1 |
ALTERNATOR - Z16XEP,Z16XE1,Z18XER,A18XER PETROL ENGINES (NEW) |
15 |
93183437 |
62 04 205 |
ALTERNATOR, ASSY., 12V.100 AMP (IDENT ZJ) (SERVICES PRODUCTION NO. 55556067) (EXCHANGE PART 93190146 OPEL, R1530094 VAUXHALL) |
Z16XEP |
(C)
(C)
(C) |
-72094718
-75086479
-78048187 |
1 |
15 |
93174469 |
62 04 123 |
ALTERNATOR, ASSY., 12V.120 AMP (IDENT XY) (SERVICES PRODUCTION NO. 24447429) (EXCHANGE PART 93189237 OPEL, R1530074 VAUXHALL) |
(C)
(C)
(C) |
-72094718
-75086479
-78048187 |
1 |
15 |
93190829 |
62 04 271 |
ALTERNATOR, ASSY., 12V.120 AMP (IDENT AL) (ALSO SERVICES 12V. 100AMP) (SERVICES PRODUCTION NOS. 13229984, 13229985) |
(C) 72094719-
(C) 75086480-
(C) 78048188-
(C) 8B000001- |
1 |
3 |
93174477 |
12 04 247 |
-PULLEY, ALTERNATOR (FOR USE WITH 100 AMP. ALTERNATOR) |
1 |
4 |
93175991 |
62 04 886 |
-NUT, HEX., M16, PULLEY TO ALTERNATOR (FOR USE WITH 100 AMP. ALTERNATOR) |
Z16XEP, Z16XE1 |
1 |
5 |
9117938 |
12 06 357 |
-BEARING, ALTERNATOR, FRONT (FOR USE WITH 100 AMP. ALTERNATOR) |
1 |
6 |
9117939 |
12 06 392 |
-RING, ALTERNATOR BEARING, REAR (FOR USE WITH 100 AMP. ALTERNATOR) |
1 |
7 |
93174476 |
12 04 246 |
-REGULATOR, ASSY., ALTERNATOR (FOR USE WITH 100 AMP. ALTERNATOR) |
1 |
8 |
93172292 |
12 05 558 |
Z16XEP, Z16XE1 |
1 |
9 |
9117940 |
12 06 358 |
-BEARING, ALTERNATOR, REAR (FOR USE WITH 100 AMP. ALTERNATOR) |
1 |
10 |
9118144 |
12 05 964 |
-CAP, PROTECTING, ALTERNATOR, REAR (FOR USE WITH 100 AMP. ALTERNATOR) |
1 |
12 |
93175984 |
12 05 602 |
-NUT, PROTECTIVE COVER FIXING (FOR USE WITH 100 AMP. ALTERNATOR) |
Z16XEP, Z16XE1 |
1 |
15 |
93188158 |
62 04 218 |
ALTERNATOR, ASSY., BOSCH 120 AMP TYPE (IDENT AB) (USED WITH AUTOMATIC TRANSMISSION) (FOR AUSTRALIA) |
Z18XER, A18XER, HATCH, ESTATE, CONVERTIBLE, VAN L08, L35, L48, L67, L70 |
1 |
ALTERNATOR - Z16XER,A16XER PETROL ENGINES (NEW) |
15 |
93174469 |
62 04 123 |
(C)
(C)
(C)
(C) |
-72094718
-75086479
-78048187
-7G070257 |
1 |
15 |
93190829 |
62 04 271 |
(C) 72094719-
(C) 75086480-
(C) 78048188-
(C) 8B000001-
(C) 7G070258- |
1 |
16 |
11102841 |
20 48 205 |
SCREW, TORX, M10 X 95, ALTERNATOR TO ALTERNATOR MOUNTING BRACKET |
2 |
ALTERNATOR - Z16XEP,Z16XE1,Z16XER,Z18XER PETROL ENGINES (EXCHANGE) |
15 |
93190146 |
62 04 268 |
ALTERNATOR, ASSY., EXCHANGE, 12V.100AMP (CORE RETURN NO. 95 62 193) (EXCEPT VAUXHALL) (IDENT ZJ) (SERVICES PRODUCTION NO. 55556067) |
Z16XEP, Z16XE1 |
(C)
(C)
(C) |
-72094718
-75086479
-78048187 |
1 |
15 |
R1530094 |
ALTERNATOR, ASSY., EXCHANGE, 12V.100AMP (FOR VAUXHALL) (CORE RETURN NO. C1530094) (IDENT ZJ) (SERVICES PRODUCTION NO. 55556067) |
Z16XEP, Z16XE1 |
(C)
(C)
(C) |
-72094718
-75086479
-78048187 |
1 |
15 |
93189237 |
62 04 235 |
ALTERNATOR, ASSY., EXCHANGE, 12V.120 AMP (CORE RETURN NO. 95 62 172) (EXCEPT VAUXHALL) (IDENT XY) (SERVICES PRODUCTION NO. 24447429) |
Z16XEP, Z16XE1, Z18XER |
(C)
(C)
(C) |
-72094718
-75086479
-78048187 |
1 |
15 |
R1530074 |
ALTERNATOR, ASSY., EXCHANGE, 12V.120 AMP (FOR VAUXHALL) (CORE RETURN NO. C1530074) (IDENT XY) (SERVICES PRODUCTION NO. 24447429) |
(C)
(C)
(C) |
-72094718
-75086479
-78048187 |
1 |
ALTERNATOR - Z16LET,A16LET PETROL ENGINES (NEW) |
15 |
93188158 |
62 04 218 |
ALTERNATOR, ASSY., BOSCH 120 AMP TYPE (IDENT AB) |
1 |
16 |
11102841 |
20 48 205 |
2 |
ALTERNATOR - Z18XE PETROL ENGINE (NEW) |
17 |
93180415 |
62 04 192 |
ALTERNATOR, ASSY., 12V.70 AMP (IDENT ZB) (EXCHANGE PART 93189246 OPEL, R1530082 VAUXHALL) |
1 |
17 |
93183436 |
62 04 204 |
ALTERNATOR, ASSY., 12V.100 AMP (IDENT ZQ) (EXCHANGE PART 93189243 OPEL, R1530079 VAUXHALL) |
1 |
18 |
93180414 |
62 04 191 |
ALTERNATOR, ASSY., 12V.120 AMP (IDENT ZA) (EXCHANGE PART 93189244 OPEL, R1530080 VAUXHALL) |
1 |
3 |
93175990 |
12 04 391 |
1 |
4 |
93175991 |
62 04 886 |
1 |
5 |
9117938 |
12 06 357 |
1 |
6 |
9117939 |
12 06 392 |
1 |
7 |
93174476 |
12 04 246 |
1 |
8 |
93182481 |
12 05 473 |
1 |
8 |
93172292 |
12 05 558 |
1 |
9 |
9117940 |
12 06 358 |
1 |
10 |
9118144 |
12 05 964 |
1 |
12 |
93175984 |
12 05 602 |
1 |
ALTERNATOR - Z18XE PETROL ENGINE (EXCHANGE) |
17 |
93189246 |
62 04 243 |
ALTERNATOR, ASSY., 12V.70 AMP, EXCHANGE (CORE RETURN NO. 95 62 180) (EXCEPT VAUXHALL) |
1 |
17 |
93189247 |
62 04 245 |
ALTERNATOR, ASSY., 12V.70 AMP, EXCHANGE (CORE RETURN NO. 95 62 181) (EXCEPT VAUXHALL) |
1 |
17 |
93189243 |
62 04 240 |
ALTERNATOR, ASSY., 12V.100 AMP, EXCHANGE (CORE RETURN NO. 95 62 177) (EXCEPT VAUXHALL) |
1 |
18 |
93189244 |
62 04 241 |
ALTERNATOR, ASSY., 12V.120 AMP, EXCHANGE (CORE RETURN NO. 95 62 178) (EXCEPT VAUXHALL) |
1 |
17 |
R1530082 |
ALTERNATOR, ASSY., 12V.70 AMP, EXCHANGE (FOR VAUXHALL) (CORE RETURN NO. C1530082) |
1 |
17 |
R1530083 |
ALTERNATOR, ASSY., 12V.70 AMP, EXCHANGE (CORE RETURN NO. C1530083) (FOR VAUXHALL) |
1 |
17 |
R1530079 |
ALTERNATOR, ASSY., 12V.100 AMP, EXCHANGE (FOR VAUXHALL) (CORE RETURN NO. C1530079) |
1 |
18 |
R1530080 |
ALTERNATOR, ASSY., 12V.120 AMP, EXCHANGE (FOR VAUXHALL) (CORE RETURN NO. C1530080) |
1 |
ALTERNATOR - Z20LEL,Z20LER,Z20LEH PETROL ENGINES (NEW) |
19 |
93180419 |
62 04 195 |
ALTERNATOR, ASSY., 12V.120 AMP (IDENT ZE) (BOSCH) (EXCHANGE PART 93189248 OPEL, R1530084 VAUXHALL) |
1 |
3 |
55352897 |
12 04 393 |
1 |
5 |
9117938 |
12 06 357 |
1 |
6 |
9117939 |
12 06 392 |
1 |
7 |
93174476 |
12 04 246 |
1 |
8 |
93172292 |
12 05 558 |
-DIODE PLATE, ALTERNATOR |
1 |
9 |
9117940 |
12 06 358 |
1 |
10 |
9118144 |
12 05 964 |
-CAP, PROTECTING, ALTERNATOR, REAR |
1 |
12 |
93175984 |
12 05 602 |
1 |
ALTERNATOR - Z20LEL,Z20LER,Z20LEH PETROL ENGINES (EXCHANGE) |
19 |
93189248 |
62 04 246 |
ALTERNATOR, ASSY., 12V.120 AMP, EXCHANGE (CORE RETURN NO. 95 62 182) (EXCEPT VAUXHALL) |
1 |
19 |
R1530084 |
ALTERNATOR, ASSY., 12V.120 AMP, EXCHANGE (FOR VAUXHALL) (CORE RETURN NO. C1530084) |
1 |
ALTERNATOR - Z22YH PETROL ENGINE (NEW) |
20 |
93183432 |
62 04 202 |
ALTERNATOR, ASSY., 12V.120 AMP (IDENT ZF) (ALSO SERVICES 12V. 100AMP) (EXCHANGE PART 93189252 OPEL, R1530095 VAUXHALL) |
(C)
(C)
(C) |
-72094718
-75086479
-78048187 |
1 |
20 |
93190828 |
62 04 270 |
ALTERNATOR, ASSY., 12V.120 AMP (IDENT AP) (ALSO SERVICES 12V. 100AMP) |
(C) 72094719-
(C) 75086480-
(C) 78048188-
(C) 8B000001- |
1 |
21 |
11518659 |
20 00 085 |
SCREW, HEX.HD., M8 X 100, ALTERNATOR TO CYLINDER BLOCK |
4 |
ALTERNATOR - Z22YH PETROL ENGINE (EXCHANGE) |
20 |
93189250 |
62 04 248 |
ALTERNATOR, ASSY., 12V.120 AMP, EXCHANGE (CORE RETURN NO. 95 62 184) (EXCEPT VAUXHALL) |
(C)
(C)
(C) |
-72094718
-75086479
-78048187 |
1 |
20 |
R1530086 |
ALTERNATOR, ASSY., 12V.120 AMP, EXCHANGE (FOR VAUXHALL) |
(C)
(C)
(C) |
-72094718
-75086479
-78048187 |
1 |
20 |
93189252 |
62 04 249 |
ALTERNATOR, ASSY., EXCHANGE, 12V.120AMP (CORE RETURN NO. 95 62 194) (EXCEPT VAUXHALL) |
1 |
20 |
R1530095 |
ALTERNATOR, ASSY., EXCHANGE, 12V.120AMP (FOR VAUXHALL) (CORE RETURN NO. C1530095) |
1 |
