Results 1 to 6 of 6
Thread: Cd30 mp3 pin
    Member u33db's Avatar
    Jun 2016
    Inverurie
    4
    Corsa D 1.6 SRI
    Cd30 mp3 pin
    Hello,
    I've bought myself a TL866 eeprom reader to try and get the security code from my CD30 MP3.
    Would someone be willing to decode the following BIN file for me?
    I have attached the file as which I *think* has been read correctly from the chip.
    Many thanks,
    Attached Files Attached Files
      thats either hex and not bin or a bad read
      try to read again
      Jun 2016
      Inverurie
      4
      Corsa D 1.6 SRI
      Sorry I've just got back to this due to work.
      Yes I read it using a SO8 clip in the hope that I wouldn't need to desolder it off the board. I've read that sometimes these can give false reads though...is it entirely necessary to desolder?
      I will try again tonight...all I am doing to connecting the clip onto the chip, noting Pin 1 position, selecting the chip type and saving the contents to a BIN file...is this definitely all I need to do?
      I suppose there is no way to know its worked until I run through the decoder?
      Member dohmniq's Avatar
      Jul 2012
      Norfolk
      41
      Corsa-C Y17DTH + Vectra-C Z19DT
      I've found the clips to be very variable and need several goes to connect properly. Another post by Pecky claims you don't need to remove the chip.
      Does you EEPROM reader give you a checksum for what's it read? If so you might spot the checksum value changing which is a sign of read issues.
      There are an awful lot of "1" bits in the first 1KB of that read.
      Jun 2016
      Inverurie
      4
      Corsa D 1.6 SRI
      Hi, thanks for the reply!
      Yes it does give a checksum as per the following screenshot (taken from another site though);
      I will give it a few attempts at reading and see how the checksum changes...last time I did it I could see the ASCII line values changing so perhaps the clip wasn't seated correctly...
      Jul 2012
      Norfolk
      41
      I've never read a CD30 (MP3?) EEPROM before but if it's like any of the others you might be able to spot the radio's serial in there somewhere (you might need to scroll down). That's usually a sign of a good EEPROM read for me.
      See this partial DAB output as an example:
      Code:
      00000000  30 30 30 30 30 30 30 30  30 30 00 00 00 00 08 06  |0000000000......|
      00000010  30 00 00 00 00 00 00 00  00 aa aa 00 00 00 00 00  |0...............|
      00000020  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
      00000030  47 4d 30 30 34 35 38 37  35 35 36 35 36 30 20 38  |GM004587556560 8|
      00000040  2e 30 30 20 20 20 20 20  20 20 20 20 96 2e 96 2f  |.00         .../|
      00000050  34 2e 30 2f 96 2e 96 20  20 2e 20 20 00 c8 0f 1a  |4.0/...  .  ....|
  1. [CARPASS] CD30 MP3. Is this correct?
    By mercenary in forum Car Pass
    Last Post: 18th June 2023, 05:45 AM
  2. Security pass CD30 MP3 ?
    By brac in forum Car Pass
    Last Post: 7th May 2020, 01:58 PM
  3. CD30 mp3 Delphi code
    By mjpenny1965@gmail.com in forum Decoding
    Last Post: 19th July 2019, 08:05 PM
  4. EEPROMS 24C32 From CD30 Mp3 Delphi Grundig pin codes
    By nicos in forum Infotainment - ICE - In Car Entertainment
    Last Post: 18th September 2018, 11:32 PM
  5. Zafira B cd30 to cd30 mp3
    By volcano12 in forum Zafira
    Last Post: 26th July 2018, 12:06 PM
