Results 1 to 3 of 3
    Fusebox Fuses and Relays
    IL Part No. KAT No. Description Range Range QTY
    FUSE BOX
    1 (13125864) (12 88 052) HOUSING, ASSY., FUSE BOX, FRONT (IDENT CJ) (NLS.- USE 13208748) (C)
    (C)
    (C)
    -52999999
    -55999999
    -58999999
    1
    1 13208748 12 87 178 HOUSING, ASSY., FUSE BOX, WITH FUSES, FRONT (IDENT MR) (C) 62000001-
    (C) 65000001-
    (C) 68000001-
    (C) 8B000001-
    (C) 6G000001-
    1
    2 93180275 62 38 070 BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS (IDENTS BK, BL, BM, BN, BP, BQ, BR, BS, BT, BU, BW) 1
    2 93182941 62 38 006 BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS (IDENT EC ALSO SERVICES IDENTS DR, DS, DT, DU, DW, DX, DY, DZ, EA, EB, FC, FD, FE, FF, FG, FH, FJ, FK, FY, FZ, GA) 1
    2 93184656 12 37 094 BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS (IDENTS GS ALSO SERVICES IDENTS GR, GT, GU, GX, GY, GZ, HA, HB, HC, LM, LN, LP, LQ, LR) 1
    2 (93189655) (12 38 386) BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS, LHD (IDENT JC) (USED WITH MANUAL TRANSMISSION) (FZM INTRO) (NLS.- USE 93190313) Z12XEP, Z14XEL, Z14XEP, Z16XEP, Z16XER, Z18XE, Z18XER (C) 52-
    (C) 55-
    (C) 58-
    72094718
    75086479
    78048187
    1
    2 93190313 12 32 099 BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS (USED WITH MANUAL TRANSMISSION) (SERVICES PRODUCTION IDENTS JZ, LK) (FOR VEHICLES WITHOUT REAR ELECTRICAL CONNECTION MODULE) Z12XEP, Z14XEL, Z14XEP, Z16XEP, Z16XE1, Z16XER, A16XER, Z18XE, Z18XER, A18XER (C) 72094719-
    (C) 75086480-
    (C) 78048188-
    (C) 8B000001-
    1
    2 (93189654) (12 38 387) BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS, LHD (IDENT JT) (USED WITH MANUAL TRANSMISSION) (FZM INTRO) (NLS.- USE 93190314) FOR DIESEL ENGINES (C) 52-
    (C) 55-
    (C) 58-
    72094718
    75086479
    78048187
    1
    2 (93190314) (12 32 100) BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS (FOR DIESEL ENGINES) (USED WITH MANUAL TRANSMISSION) (SERVICES PRODUCTION IDENT KA) (FOR LOW COST VARIANTS) (FOR VEHICLES WITHOUT REAR ELECTRICAL CONNECTION MODULE) (NLS.- USE 93194877) HATCH, ESTATE L08, L35, L48 (C) 72094719-
    (C) 75086480-
    (C) 78048188-
    (C) 8B000001-
    1
    3 13125865 62 88 264 LID, FUSE BOX, FRONT 1
    4 13129783 62 88 263 COVER, FUSE BOX, FRONT 1
    5 11086944 20 64 896 NUT, FUSE BOX, M6, FRONT 1
    6 11900440 23 19 533 NUT, FUSE BOX, M8, FRONT 1
    7 93182631 62 38 071 BOX, FUSE, REAR BODY WIRING HARNESS, WITH FUSES AND RELAYS (IDENTS CA, CB, CC, CD, CE, CF, CG, CH) (C)
    (C)
    -45999999
    -48999999
    1
    7 93182940 62 38 074 BOX, FUSE, REAR BODY WIRING HARNESS, WITH FUSES AND RELAYS (IDENTS DH, DJ, DK, DL, DM, DN, DP, DQ) (C) 52000001-
    (C) 55000001-
    (C) 58000001-
    52
    55176806
    58038187
    1
    7 93184968 12 37 177 BOX, FUSE, REAR BODY WIRING HARNESS, WITH FUSES AND RELAYS (SERVICES PRODUCTION IDENTS HD, HE, HF, HG, HH, HJ, HK, HL) (C) 52-
    (C) 55176807-
    (C) 58038188-
    62111111
    65118966
    68086940
    1
    7 93191289 12 38 397 BOX, FUSE, REAR BODY WIRING HARNESS, WITH FUSES AND RELAYS (IDENT JM) (SERVICES PRODUCTION IDENTS KA, KB, KC) (C) 82000001-
    (C) 85000001-
    (C) 88000001-
    (C) 8B000001-
    1
    7 93188419 12 38 854 BOX, FUSE, REAR BODY WIRING HARNESS, WITH FUSES AND RELAYS (SERVICES PRODUCTION IDENTS HN, HP, HQ, HR, HT, HU, HY, HX, LH, LJ) (C) 62112000-
    (C) 65118967-
    (C) 68086941-
    (C) 8B000001-
    1
    8 13155752 73 36 936 KNOB, LOCKING, FUSE BOX, REAR, RH 1
    8 13155752 73 36 936 KNOB, LOCKING, FUSE BOX, REAR, LH 2
    9 90253990 23 46 823 CLIP, RETAINING, FUSE BOX COVER, REAR, RH HATCH L08, L48 1
    9 90253990 23 46 823 CLIP, RETAINING, FUSE BOX COVER, REAR, LH HATCH L08, L48 2
    10 90332705 23 46 828 CLIP, RETAINING, FUSE BOX COVER, REAR, LH ESTATE, VAN L35, L70 2
    11 11900428 20 64 809 NUT, FUSE BOX, M6, REAR HATCH, ESTATE, CONVERTIBLE, VAN L08, L35, L48, L67, L70 1
    12 11900511 20 05 243 SCREW, TORX, M8 X 30, FUSE BOX FIXING, REAR ESTATE, VAN L35, L70 1
    13 13115937 62 88 430 BRACKET, FUSE BOX, REAR ESTATE, VAN L35, L70 1
    14 13193579 12 87 031 BRACKET, FUSE BOX, REAR CONVERTIBLE L67 1
      FUSES
      1 9196441 62 38 299 FUSE, MINI, 5 AMP (PACK OF 50) AR
      1 90542150 62 38 285 FUSE, MINI, 10 AMP (PACK OF 50) (EXCEPT VAUXHALL) AR
      1 91153942 FUSE, MINI, 10 AMP (PACK OF 50) (FOR VAUXHALL) AR
      1 90542151 62 38 286 FUSE, MINI, 15 AMP (PACK OF 50) AR
      1 90542152 62 38 287 FUSE, MINI, 20 AMP (PACK OF 50) AR
      1 12092076 12 38 297 FUSE, MINI, 25 AMP (PACK OF 50) AR
      1 24426658 FUSE, 25 AMP (NATURAL) AR
      1 90386023 12 38 296 FUSE, 50 AMP, RED AR
      2 13133859 12 38 302 FUSE, 20 AMP (BLUE) AR
      2 13171756 12 38 381 FUSE, 25 AMP (NATURAL) AR
      2 13133860 12 38 305 FUSE, 30 AMP (PINK) AR
      2 13133861 12 38 306 FUSE, 40 AMP (GREEN) AR
      2 13133862 12 38 379 FUSE, 50 AMP (RED) AR
      2 13133863 12 38 380 FUSE, 60 AMP (YELLOW) AR
      2 13180511 62 38 065 FUSE, 80 AMP AR
      3 13133865 62 35 736 FUSE, 40 AMP (GREEN) AR
      3 13133867 62 35 737 FUSE, 60 AMP (YELLOW) AR
      3 13133868 62 35 738 FUSE, 70 AMP (BROWN) AR
      3 13133869 62 35 739 FUSE, 80 AMP AR
      3 13133870 62 38 740 FUSE, 100 AMP (BLUE) AR
      3 13133871 62 35 741 FUSE, 125 AMP (PINK) AR
      4 93175319 62 38 044 FUSE, STRIP, 80 AMP (PACK OF 10) AR
      4 93175320 62 38 045 FUSE, STRIP, 110 AMP (PACK OF 25) AR
      5 13152697 12 88 974 CLAMP, FUSE PULLER, FUSE BOX 1
      RELAYS
      1 93177596 62 38 633 RELAY, RADIATOR FAN (ZUS-50) (FOR MANUAL AIR CONDITIONING) (USED WITH AUTOMATIC TRANSMISSION) Z18XE (C)
      (C)
      (C)
      (C)
      -42113729
      -45120574
      -48050024
      -4G026201
      AR
      1 93168566 12 47 025 RELAY, RADIATOR FAN (ZUS-50) (FOR MANUAL AIR CONDITIONING) (USED WITH AUTOMATIC TRANSMISSION) Z18XE (C) 42113730-
      (C) 45120575-
      (C) 48050025-
      (C) 4G026202-
      (C) 8B000001-
      AR
      1 93177596 62 38 633 RELAY, RADIATOR FAN (ZUS-50) (FOR AIR CONDITIONING) Z20LEL, Z20LER, Z22YH, Z13DTH, Z17DTL, Z17DTH, Z19DT, Z19DTH (C)
      (C)
      (C)
      (C)
      -42113729
      -45120574
      -48050024
      -4G026201
      AR
      1 93168566 12 47 025 RELAY, RADIATOR FAN (ZUS-50) (FOR AIR CONDITIONING) Z20LEL, Z20LER, Z22YH, Z13DTH, Z17DTL, Z17DTH, Z19DT, Z19DTH (C) 42113730-
      (C) 45120575-
      (C) 48050025-
      (C) 4G026202-
      (C) 8B000001-
      AR
      2 93181061 62 38 639 RELAY, RADIATOR FAN (ZUS-55) (FOR MANUAL AIR CONDITIONING) (USED WITH AUTOMATIC TRANSMISSION) Z18XE (C)
      (C)
      (C)
      (C)
      -42113729
      -45120574
      -48050024
      -4G026201
      AR
      2 93168568 12 47 027 RELAY, RADIATOR FAN (ZUS-55) (FOR MANUAL AIR CONDITIONING) (USED WITH AUTOMATIC TRANSMISSION) Z18XE (C) 42113730-
      (C) 45120575-
      (C) 48050025-
      (C) 4G026202-
      82
      85
      88
      8G
      AR
      Note: RANGE: BREAKPOINT INFORMATION NOT YET AVAILABLE
      2 93196426 62 38 007 RELAY, RADIATOR FAN (ZUS-91) (FOR MANUAL AIR CONDITIONING) (USED WITH AUTOMATIC TRANSMISSION) Z18XE (C) 82-
      (C) 85-
      (C) 88-
      (C) 8G-
      AR
      2 93181061 62 38 639 RELAY, RADIATOR FAN (ZUS-55) (FOR AIR CONDITIONING) Z20LEL, Z20LER, Z22YH, Z13DTH, Z17DTL, Z17DTH, Z19DT, Z19DTH (C)
      (C)
      (C)
      (C)
      -42113729
      -45120574
      -48050024
      -4G026201
      AR
      2 93168568 12 47 027 RELAY, RADIATOR FAN (ZUS-55) (FOR AIR CONDITIONING) Z20LEL, Z20LER, Z22YH, Z13DTH, Z17DTL, Z17DTH, Z19DT, Z19DTH (C) 42113730-
      (C) 45120575-
      (C) 48050025-
      (C) 4G026202-
      82
      85
      88
      8G
      AR
      2 93196426 62 38 007 RELAY, RADIATOR FAN (ZUS-91) (FOR AIR CONDITIONING) Z20LEL, Z20LER, Z22YH, Z13DTH, Z17DTL, Z17DTH, Z19DT, Z19DTH (C) 82-
      (C) 85-
      (C) 88-
      (C) 8G-
      AR
      3 93177597 62 38 634 RELAY, ADDITIONAL WATER PUMP (ZUS-51) Z20LEL, Z20LER (C)
      (C)
      (C)
      (C)
      -42113729
      -45120574
      -48050024
      -4G026201
      AR
      3 93168567 12 47 026 RELAY, ADDITIONAL WATER PUMP (ZUS-51) Z20LEL, Z20LER (C) 42113730-
      (C) 45120575-
      (C) 48050025-
      (C) 4G026202-
      (C) 8B000001-
      AR
      4 (24435922) (62 38 610) RELAY, MULTI-USE, BLACK (FOR REPAIR) (NLS.- USE 13266316) AR
      Note: PLEASE REFER TO TIS FOR USAGE
      5 90543014 62 38 564 RELAY, MULTI-USE, BROWN (FOR REPAIR) AR
      6 13171831 62 38 640 RELAY, MULTI-USE, BLACK (DELAY RELAY) (FOR REPAIR) AR
      6 24438887 62 38 626 RELAY, MULTI-USE, RED (DELAY RELAY) (FOR REPAIR) AR
      7 90226846 12 38 612 RELAY, MULTI-USE, YELLOW AR
      8 93172269 62 38 623 RELAY, MULTI-USE, GREY AR
      9 13125543 62 38 060 RELAY, FOLDING ROOF CONVERTIBLE L67 1
  1. UEC fusebox
    By bruce1234 in forum Zafira
    Last Post: 5th June 2015, 08:00 AM
  2. Ac relays
    By wharton in forum Electrical
    Last Post: 27th July 2014, 12:47 PM
  3. 10 - Fuse Box, Fuses & Relays
    By pecky in forum P - ELECTRICAL
    Last Post: 28th December 2013, 05:32 PM
astra H relay diagram
astra h relay layout
zafira b fuse box layout
vauxhall corsa relays diagram
zafira b fuse box diagram
zafira b relay diagram
zafira b relay locationsvauxhall zafira fuse box layoutzafira b relay layoutvauxhall zafira fuse box diagramastra h aircon relayzafira relay diagramvauxhall astra h relay diagram13125543 RELAY FOLDING ROOFastra mk5 relaysopel astra h fues and relay lablesvauxhall astra h relay layout https:diagnostics.org.ukshowthread.php602-Fusebox-Fuses-and-Relaysastra h relay locationsastra h air con relayastra mk5 relay diagramzafira b z16xep fuse box diagramcorsa c relays diagramastra h power roof relayfuse box relay diagram zafira b
