IL |
Part No. |
KAT No. |
Description |
Range |
Range |
QTY |
INDUCTION MANIFOLD VACUUM SENSOR - Z16XEP,Z16XE1 PETROL ENGINES |
1 |
16212460 |
62 38 120 |
SENSOR, VACUUM, INLET MANIFOLD PRESSURE |
(C)
(C)
(C) |
-62999999
-65999999
-68999999 |
1 |
1 |
16212460 |
62 38 120 |
SENSOR, VACUUM, INLET MANIFOLD PRESSURE (EXCEPT PRODUCTION OPTION CODE WEM) |
(C) 72000001-
(C) 75000001-
(C) 78000001- |
72999999
75999999
78999999 |
1 |
2 |
93192107 |
12 38 894 |
SENSOR, VACUUM, INLET MANIFOLD PRESSURE (FOR PRODUCTION OPTION CODE WEM) |
(C) 72000001-
(C) 75000001-
(C) 78000001- |
72999999
75999999
78999999 |
1 |
2 |
93192107 |
12 38 894 |
(C) 82000001-
(C) 85000001-
(C) 88000001-
(C) 8G000001-
(C) 8B000001- |
1 |
3 |
25343069 |
58 15 110 |
BRACKET, VACUUM SENSOR, INDUCTION MANIFOLD |
(C)
(C)
(C) |
-62999999
-65999999
-68999999 |
1 |
3 |
25343069 |
58 15 110 |
BRACKET, VACUUM SENSOR, INDUCTION MANIFOLD (EXCEPT PRODUCTION OPTION CODE WEM) |
(C) 72000001-
(C) 75000001-
(C) 78000001- |
72999999
75999999
78999999 |
1 |
4 |
11097981 |
20 05 624 |
SCREW, TORX, M6 X 16, BRACKET FIXING |
1 |
INDUCTION MANIFOLD VACUUM SENSOR - Z16XER,A16XER,Z18XER,A18XER PETROL ENGINES |
5 |
55563375 |
12 38 394 |
1 |
8 |
55561869 |
58 50 711 |
SCREW, PLUG, M6 X 38 |
Z18XER, A18XER |
1 |
INDUCTION MANIFOLD VACUUM SENSOR - Z16LET,A16LET,Z20LEL,Z20LER,Z20LEH PETROL ENGINES |
6 |
9117763 |
62 38 084 |
1 |
7 |
11097981 |
20 05 624 |
SCREW, TORX, M6 X 16, VACUUM SENSOR TO INLET MANIFOLD |
1 |
INDUCTION MANIFOLD VACUUM SENSOR - Z17DTJ,A17DTJ, Z17DTR, A17DTR DIESEL ENGINES |
63 |
97381191 |
62 38 678 |
SENSOR, BOOST PRESSURE, INLET MANIFOLD |
1 |
64 |
11518061 |
20 05 058 |
SCREW, M6 X 13, VACUUM SENSOR TO INDUCTION MANIFOLD |
2 |
INDUCTION MANIFOLD VACUUM SENSOR - Z17DTL,Z17DTH DIESEL ENGINES |
X |
SENSOR, BOOST PRESSURE, INLET MANIFOLD (PLEASE REFER TO GROUP G) (TURBOCHARGER VACUUM SYSTEM) |
INDUCTION MANIFOLD VACUUM SENSOR - Z13DTH,Z19DTL,Z19DT,Z19DTJ,Z19DTH DIESEL ENGINES |
9 |
93171176 |
62 38 210 |
Z13DTH, Z19DTL, Z19DT |
1 |
9 |
55206797 |
62 38 865 |
Z19DTJ, Z19DTH |
1 |
10 |
93181936 |
8 55 969 |
SCREW, M6 X 25, VACUUM SENSOR TO INDUCTION MANIFOLD |
Z19DTL, Z19DT |
1 |
10 |
93178850 |
58 51 361 |
SCREW, M6 X 20, VACUUM SENSOR TO INDUCTION MANIFOLD |
Z19DTJ, Z19DTH |
1 |
CATALYTIC CONVERTER SENSOR - Z12XEP,Z14XEL,Z14XEP PETROL ENGINES |
11 |
93177169 |
8 55 402 |
SENSOR, OXYGEN, CATALYTIC CONVERTER (POSITION 1) |
(C)
(C)
(C) |
-52999999
-55999999
-58999999 |
1 |
11 |
93177451 |
8 55 406 |
(C) 62000001-
(C) 65000001-
(C) 68000001- |
62
65
68 |
1 |
Note: RANGE: NO BREAKPOINT INFORMATION AVAILABLE |
11 |
(93186800) |
(8 55 516) |
SENSOR, OXYGEN, CATALYTIC CONVERTER (POSITION 1) (RANGE: NO ADDITIONAL PLANT BREAKPOINT INFORMATION AVAILABLE) (NLS.- USE 93190419) |
(C) 62-
(C) 65-
(C) 68-
68- |
19KP7461
19KP7461
19KP7461
19KP7461 |
1 |
11 |
93190419 |
8 55 528 |
SENSOR, OXYGEN, CATALYTIC CONVERTER (POSITION 1) (SERVICES PRODUCTION NO. 55561863) |
(E) 19KP7462- |
1 |
11 |
93177450 |
8 55 405 |
SENSOR, OXYGEN, WITH HARNESS, FRONT EXHAUST PIPE (POSITION 2) (IDENT BZ) |
1 |
12 |
24459734 |
62 88 958 |
CLIP, OXYGEN SENSOR WIRE |
2 |
13 |
90039907 |
12 88 900 |
STRAP, RETAINING, 290MM |
AR |
CATALYTIC CONVERTER SENSOR - Z16XEP,Z16XE1 PETROL ENGINES |
14 |
93174519 |
8 55 510 |
(E) |
-20HH5427 |
1 |
15 |
93181910 |
8 55 268 |
(E) 20HH5428- |
1 |
14 |
(24435098) |
(8 55 396) |
SENSOR, OXYGEN, CATALYTIC CONVERTER (POSITION 2) (NLS.- USE 55560617) |
(C)
(C) |
-45999999
-48999999 |
1 |
14 |
55560617 |
8 55 429 |
SENSOR, OXYGEN, CATALYTIC CONVERTER (POSITION 2) (IDENT CP) |
(C) 52000001-
(C) 55000001-
(C) 58000001- |
62999999
65999999
68999999 |
1 |
14 |
55560617 |
8 55 429 |
SENSOR, OXYGEN, CATALYTIC CONVERTER (POSITION 2) (IDENT CP) (EXCEPT PRODUCTION OPTION CODE WEM) |
(C) 72000001-
(C) 75000001-
(C) 78000001- |
72999999
75999999
78999999 |
1 |
14 |
55566746 |
58 55 378 |
SENSOR, OXYGEN, CATALYTIC CONVERTER (POSITION 2) (IDENT DP) (FOR PRODUCTION OPTION CODE WEM) |
(C) 72000001-
(C) 75000001-
(C) 78000001- |
72999999
75999999
78999999 |
1 |
14 |
55566746 |
58 55 378 |
SENSOR, OXYGEN, CATALYTIC CONVERTER (POSITION 2) (IDENT DP) |
(C) 82000001-
(C) 85000001-
(C) 88000001-
(C) 8G000001-
(C) 8B000001- |
1 |
16 |
9152977 |
62 38 829 |
1 |
17 |
90320964 |
12 88 596 |
STRAP, RETAINING, OXYGEN SENSOR WIRE |
1 |
13 |
90039907 |
12 88 900 |
AR |
CATALYTIC CONVERTER SENSOR - Z16LET,A16LET PETROL ENGINES |
11 |
93186233 |
8 55 428 |
SENSOR, OXYGEN, WITH HARNESS, FRONT EXHAUST PIPE (POSITION 1) (IDENT CT) |
1 |
18 |
93190243 |
8 55 456 |
SENSOR, OXYGEN, WITH HARNESS, FRONT EXHAUST PIPE (IDENT CY) (POSITION 2) |
Z16LET |
1 |
19 |
55564243 |
58 55 384 |
SENSOR, OXYGEN, HEATED, CATALYTIC CONVERTER (POSITION 2) (IDENT DL) |
A16LET |
1 |
20 |
55556642 |
12 87 003 |
1 |
21 |
24408999 |
12 88 692 |
BRACKET, OXYGEN SENSOR WIRE |
2 |
22 |
11089474 |
20 66 916 |
NUT, M6, WITH WASHER, CLIP FIXING |
1 |
CATALYTIC CONVERTER SENSOR - Z18XE PETROL ENGINE |
23 |
9202575 |
8 55 356 |
1 |
24 |
9158718 |
8 55 389 |
SENSOR, OXYGEN, WITH HARNESS, FRONT EXHAUST PIPE (POSITION 2) |
1 |
25 |
90356696 |
12 38 808 |
1 |
13 |
90039907 |
12 88 900 |
AR |
CATALYTIC CONVERTER SENSOR - Z16XER,A16XER,Z18XER,A18XER PETROL ENGINES |
11 |
93185456 |
8 55 422 |
SENSOR, OXYGEN, WITH HARNESS, FRONT EXHAUST PIPE (POSITION 1) (IDENT CN) |
1 |
11 |
93189215 |
8 55 453 |
SENSOR, OXYGEN, WITH HARNESS, FRONT EXHAUST PIPE (POSITION 2) (IDENT DA) |
Z16XER, A16XER |
1 |
11 |
93185493 |
8 55 426 |
Z18XER, A18XER |
1 |
20 |
24432956 |
62 88 905 |
2 |
12 |
24459734 |
62 88 958 |
1 |
13 |
90039907 |
12 88 900 |
AR |
CATALYTIC CONVERTER SENSOR - Z20LEL,Z20LER,Z20LEH PETROL ENGINES |
11 |
9193148 |
8 55 355 |
SENSOR, OXYGEN, WITH HARNESS, FRONT EXHAUST PIPE (POSITION 1) |
1 |
26 |
9201421 |
8 55 378 |
1 |
20 |
55556642 |
12 87 003 |
1 |
21 |
24408999 |
12 88 692 |
2 |
22 |
11089474 |
20 66 916 |
1 |
13 |
90039907 |
12 88 900 |
AR |
CATALYTIC CONVERTER SENSOR - Z22YH PETROL ENGINE |
11 |
93185493 |
8 55 426 |
SENSOR, OXYGEN, WITH HARNESS, FRONT EXHAUST PIPE (POSITION 1) (IDENT DA) |
1 |
27 |
93184575 |
8 55 414 |
SENSOR, OXYGEN, WITH HARNESS, FRONT EXHAUST PIPE (POSITION 2) (IDENT CM) |
1 |
20 |
55556642 |
12 87 003 |
1 |
28 |
55557737 |
12 87 014 |
1 |
21 |
24408999 |
12 88 692 |
2 |
22 |
11089474 |
20 66 916 |
1 |
CATALYTIC CONVERTER SENSOR - Z13DTH DIESEL ENGINE NOT USED WITH EASYTRONIC TRANSMISSION |
29 |
93185159 |
8 55 419 |
SENSOR, OXYGEN, WITH HARNESS (NOT USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
1 |
30 |
55558701 |
62 88 447 |
BRACKET, OXYGEN SENSOR (NOT USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
1 |
31 |
11100961 |
20 05 244 |
SCREW, M8 X 18, BRACKET FIXING (NOT USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
1 |
32 |
24435616 |
18 18 730 |
CLIP, OXYGEN SENSOR WIRE (NOT USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
2 |
33 |
55558703 |
62 88 479 |
1 |
CATALYTIC CONVERTER SENSOR - Z17DTJ,A17DTJ, Z17DTR, A17DTR DIESEL ENGINES |
34 |
98075140 |
8 55 877 |
SENSOR, OXYGEN, WITH HARNESS (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
A17DTJ, A17DTR |
1 |
35 |
98030739 |
12 88 857 |
BRACKET, OXYGEN SENSOR |
1 |
36 |
55563226 |
12 38 856 |
BRACKET, OXYGEN SENSOR WIRE (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
2 |
37 |
55563442 |
8 55 525 |
2 |
20 |
55556642 |
12 87 003 |
CLIP, OXYGEN SENSOR WIRE (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
1 |
21 |
24408999 |
12 88 692 |
2 |
13 |
24409083 |
18 26 124 |
STRAP, RETAINING, OXYGEN SENSOR WIRE (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
AR |
38 |
13182778 |
8 55 872 |
AR |
CATALYTIC CONVERTER SENSOR - Z19DTL,Z19DT,Z19DTJ,Z19DTH DIESEL ENGINES |
34 |
93179226 |
8 55 506 |
SENSOR, OXYGEN, WITH HARNESS (NOT USED WITH EXHAUST SYSTEM PARTICLE FILTER) (FOR RETROFIT PARTICLE FILTER) |
1 |
35 |
55355453 |
62 88 426 |
BRACKET, OXYGEN SENSOR (NOT USED WITH EXHAUST SYSTEM PARTICLE FILTER) (FOR RETROFIT PARTICLE FILTER) |
1 |
36 |
55563226 |
12 38 856 |
2 |
20 |
55556642 |
12 87 003 |
1 |
20 |
24432956 |
62 88 905 |
2 |
39 |
90341589 |
62 88 619 |
1 |
21 |
24408999 |
12 88 692 |
BRACKET, OXYGEN SENSOR WIRE, POSITION 2 (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
2 |
13 |
90039907 |
12 88 900 |
AR |
22 |
11089474 |
20 66 916 |
1 |
EXHAUST TEMPERATURE SENSOR - Z13DTH DIESEL ENGINE |
40 |
93188473 |
8 55 267 |
SENSOR, EXHAUST TEMPERATURE (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
1 |
17 |
24409083 |
18 26 124 |
STRAP, RETAINING |
AR |
41 |
24441505 |
8 85 160 |
STRAP, RETAINING |
AR |
EXHAUST TEMPERATURE SENSOR - Z17DTJ,A17DTJ,Z17DTR,A17DTR DIESEL ENGINES |
42 |
93189198 |
8 55 438 |
SENSOR, EXHAUST TEMPERATURE (POSITION 1) (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
1 |
65 |
55566086 |
58 55 375 |
SENSOR, EXHAUST TEMPERATURE (POSITION 2) |
Z17DTJ, Z17DTR |
1 |
38 |
13182778 |
8 55 872 |
-STRAP, RETAINING |
Z17DTJ, Z17DTR |
AR |
13 |
24409083 |
18 26 124 |
-STRAP, RETAINING |
Z17DTJ, Z17DTR |
AR |
66 |
55566631 |
58 55 377 |
SENSOR, EXHAUST TEMPERATURE (POSITION 2) (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
A17DTJ, A17DTR |
1 |
67 |
55566621 |
58 55 376 |
SENSOR, EXHAUST TEMPERATURE (USED WITH EXHAUST SYSTEM PARTICLE FILTER) (POSITION 3) |
A17DTJ, A17DTR |
1 |
68 |
90039907 |
12 88 900 |
STRAP, RETAINING, 290 MM LONG, CABLE, EXHAUST TEMPERATURE SENSOR (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
A17DTJ, A17DTR |
1 |
EXHAUST TEMPERATURE SENSOR - Z19DTL,Z19DT,Z19DTJ,Z19DTH DIESEL ENGINES |
43 |
55355404 |
8 55 410 |
1 |
44 |
55558578 |
8 55 412 |
1 |
45 |
55355415 |
8 55 869 |
BRACKET, SENSOR, EXHAUST TEMPERATURE |
1 |
46 |
55355403 |
8 55 978 |
BRACKET, CONNECTOR, EXHAUST TEMPERATURE SENSOR (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
1 |
47 |
55350596 |
62 88 434 |
BRACKET, CONNECTOR, EXHAUST TEMPERATURE SENSOR (USED WITH AUTOMATIC TRANSMISSION) |
1 |
48 |
93182794 |
20 00 247 |
SCREW, BRACKET RETAINING, M10 X 20 |
1 |
49 |
11095322 |
20 64 895 |
NUT, HEX., M8, CONNECTOR BRACKET (USED WITH AUTOMATIC TRANSMISSION) |
1 |
EXHAUST PRESSURE DIFFERENTIAL SENSOR - Z13DTH DIESEL ENGINE |
50 |
55566186 |
8 62 040 |
SENSOR, EXHAUST PRESSURE DIFFERENCE |
1 |
51 |
55561053 |
8 62 775 |
BRACKET, EXHAUST PRESSURE DIFFERENTIAL SENSOR (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
1 |
52 |
55560353 |
8 62 418 |
BRACKET, EXHAUST PRESSURE DIFFERENTIAL SENSOR (USED WITH EASYTRONIC TRANSMISSION) |
1 |
53 |
11099701 |
20 05 015 |
SCREW, TORX, M8 X 20, PIPE, SENSOR |
1 |
54 |
11094425 |
20 64 884 |
NUT, HEX., M6, EXHAUST PRESSURE DIFFERENCE SENSOR |
1 |
54 |
11900428 |
20 64 809 |
NUT, HEX., M6, EXHAUST PRESSURE DIFFERENCE SENSOR, BRACKET |
1 |
54 |
11900428 |
20 64 809 |
NUT, HEX., M6, EXHAUST PRESSURE DIFFERENCE SENSOR, BRACKET (USED WITH EASYTRONIC TRANSMISSION) |
1 |
55 |
90262367 |
14 04 926 |
RIVET, EXPANDING, EXHAUST PRESSURE DIFFERENTIAL SENSOR |
1 |
56 |
90575310 |
3 02 902 |
RIVET NUT, M8, BRACKET FIXING, PIPE, SENSOR |
(C)
(C)
(C) |
-62999999
-65999999
-68999999 |
1 |
EXHAUST PRESSURE DIFFERENTIAL SENSOR - Z17DTJ,A17DTJ, Z17DTR, A17DTR DIESEL ENGINES |
50 |
93187247 |
8 62 715 |
SENSOR, EXHAUST PRESSURE DIFFERENCE (USED WITH EXHAUST SYSTEM PARTICLE FILTER) |
1 |
54 |
11094425 |
20 64 884 |
1 |
58 |
11097401 |
20 48 979 |
SCREW, M6 X 12, BRACKET FIXING |
1 |
EXHAUST PRESSURE DIFFERENTIAL SENSOR - Z19DTL,Z19DT,Z19DTJ,Z19DTH DIESEL ENGINES |
57 |
93185556 |
8 62 023 |
SENSOR, EXHAUST PRESSURE DIFFERENCE (USED WITH EXHAUST SYSTEM PARTICLE FILTER) (FOR RETROFIT PARTICLE FILTER) |
HATCH, ESTATE L08, L35, L48 |
(C)
(C)
(C) |
-62167207
-65165230
-68124718 |
1 |
50 |
93187247 |
8 62 715 |
HATCH, ESTATE, VAN L08, L35, L48, L70 |
(C) 62167208-
(C) 65165231-
(C) 68124719-
(C) 8B000001- |
1 |
50 |
93187247 |
8 62 715 |
CONVERTIBLE L67 |
1 |
54 |
11094425 |
20 64 884 |
1 |
54 |
11094425 |
20 64 884 |
NUT, HEX., M6, EXHAUST PRESSURE DIFFERENTIAL SENSOR BRACKET |
3 |
59 |
55558110 |
8 62 917 |
CLIP, SENSOR PIPE, LHD |
1 |
60 |
55558111 |
8 62 918 |
CLIP, SENSOR PIPE, RHD |
1 |
INTERCOOLER SENSOR - Z16LET,A16LET,Z20LEL,Z20LER,Z20LEH PETROL ENGINES |
61 |
93170309 |
12 38 244 |
SENSOR, AIR TEMPERATURE AND CHARGE AIR PRESSURE |
1 |
62 |
93170311 |
12 38 727 |
SEAL, RING, SENSOR |
1 |
58 |
11097791 |
20 05 995 |
SCREW, TORX, M6 X 12, SENSOR FIXING |
Z16LET, A16LET |
1 |
