What gains would I expect to get if I get my z20lel 170 bhp mapped its got vxr turbo,fmic,crossover delete,scorpion precat,decatted and no middle box etc
without an exhaust and cooler i would say about another 30 bhp to run it safe
Spoke to sm tuning and they said they can get it to 250+ but a few people said not to use them
Nothing wrong at all with Sean's maps, he's a very good tuner and knows the engines well
I'm only goin off what a couple lads said at a car meet
Yh they've probably had an issue on a car after being mapped and blame the mapper
Trust me here's nothing to worry about, as long as you let him know you want reliable safe power to use daily he won't push stuff to its limit
Sound mate I'll giv him a call
the problem with alot of ppl they get there car mapped to the setup there running then later change parts which does effect the way the car will run and then blame the mapper if its running rough or lean, every mod you stick on the car after its mapped the map should be tweaked ideally to suit the new changes
You definitely need a bigger FMIC and probably an exhaust before you go above VXR power, at worst you could go for both items from a VXR and then at least you're safe to run 250ish
OP says got FMIC? just doesn't say what exhaust?
