Hello guys and girls
Can anyone point me.in the direction of the relays that are associated with ac system ??
I am lead to belive it is k8 ?? However I cannot locate this one on the board ?? Anyone have knowledge on this ??
Thanks all
Thanks all
You got climate control or plain A/C ?
Plain ac matey
What's up with it ?
Ac clutch doesn't engage when you press ac button. Rev's drop but no cold air
Regas needed by anychance ? I was told if ther is no gas the clutch wont kick in . Jm not 100% on this as mine is also buggered. Plain ac press the button , no light no rev drop nothing . The last I know of this 2 work heard a slight "pop" im also not sure on relays so could be very simple .
Yeah thats basically an indication that your gas has gone, the clutch wont kick in as it stops the compressor from burning out
I have had it re gassed ??
A garage has suggested that a relay on the box operates the clutch on the ac ?? Just don't sans spend £20+ on a relay if it's not that. Anyone able to test a relay ??
Was it pressure tested first ?
