Results 1 to 6 of 6
    Member LeeMutz's Avatar
    Mar 2014
    Gloucester
    25
    Astra H VXR
    AFL retrofit on my estate
    Hi guys
    I've stumbled across a cheap set of AFL's.
    I have the following so far.
    AFL's
    AFL control unit/module
    Rear beam level sensor/bracket
    Headlamp switch
    Now I know I need the Earth mod looms, and the main loom from hopefully [MENTION=4]Pecky[/MENTION] if he has time to do one as I noticed he has none in stock on his site.
    Now, apart from fitting the said items, and having Tech2 work done, am I missing anything??
    Thanks guys
    Lee
      VIP Gairo's Avatar
      Aug 2010
      Wombourne, South Staffs
      3,060
      Astra 1.9 16v CDTi SRi XP+ Power Red Estate
      That sounds like most of it Lee, are you fitting headlamp washers ?
      VIP Gairo's Avatar
      Aug 2010
      3,060
      This is the list of parts needed according to www.diagnostics.org.uk
      Headlamp, ASSY, LH-LH Traffic
      Headlamp, ASSY, RH-LH Traffic
      Control Unit, headlamp levelling, (used with AFL)
      Control Unit, Headlamp Ignition with seal
      Control Unit Headlamps
      Sensor, Headlamp levelling
      Nut, Hex, M6, sensor to rear axle
      Bracket, Headlamp levelling sensor
      Control Unit, Angle, Headlamps, (Used with AFL)
      Electrical connector for levelling sensor.
      Light switch without manual levelling switch.
      Mar 2014
      Gloucester
      25
      Astra H VXR
      Sounds good to me...
      Will fit them at a later date Chris yes, I know it 'should' fail an MOT but I think I'll be OK for a few reasons
      I just need to find the connectors for the rear level sensor, I've found everything else to make the looms.
      Mar 2014
      Gloucester
      25
      Astra H VXR
      Thanks mate. Keep me posted and ill pop up to yours again when convenient
      thanks mate appreciate it
  1. Signums AFL retrofit
    By EdopcBurg in forum Vectra
    Last Post: 6th January 2019, 08:12 PM
