[MENTION=676]LeeMutz[/MENTION], it all depends on if you have PEPS or not, generally, the PEPS dashboard loom is a complete one which I believe has the heated seat wiring already fitted, anything else will generally need the extra wires, chances are you have the standard (non PEPS) loom. The wiring to light up the switches is probably already there in which case they'll light up but they won't do much else. You will need Tech 2 to finish it off.
